01-13-2011, 11:56 PM | #1 |
Rock Crawler Join Date: Nov 2008 Location: Maple Ridge, BC, CANADA
| winch servo(hitec645) and DX3e
so i just built myself a servo winch from this thread....http://www.rccrawler.com/forum/showthread.php?t=17970 everything went as planned except for the DX3e part. I cant figure out how to get the winch to spin both ways? I can get it to spin one way(pull line out) no problem and then make it stop but i can not make it spin back the other way(bring line in) can anyone help me out with this problem...it a brand new radio...dont know to much about it.. |
01-14-2011, 05:10 PM | #2 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
Have you got the switch on the DX3e set to the 3p mode. If so did you adjust the pot inside the servo to ensure you had a neutral. If you've done both of these its got me fawked. |
01-14-2011, 11:16 PM | #3 |
01-14-2011, 11:18 PM | #4 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
adjust the hi/lo settings for channel 3 on top of the radio
01-15-2011, 05:57 PM | #5 |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
well, was that the answer?
01-15-2011, 06:14 PM | #6 |
nope, not the answer! i did adjust the hi/lo settings for channel 3 on top of the radio. all it did was make the servo spin none stop where the switch on remote wont do anything..... |
01-16-2011, 02:32 PM | #7 |
does this have anything to do with me making new switch points....? |
01-16-2011, 02:33 PM | #8 |
really need help, cause I really have no idea where this went wrong....
01-19-2011, 12:30 AM | #9 |
So, did something completely go wrong??
01-22-2011, 07:17 PM | #10 |
RCC Addict Join Date: Apr 2006 Location: Brighton
Did you try testing the winch servo in your steering channel? That should tell you if it's the programing of the radio for the 3rd channel. It sounds like your travel adjustments (EPA) may not be set for the opposite direction (+100 to run it out -100 to run it in). If you adjust the radio so the 3rd channel is opposite of the current direction ( REV/NORM ) does the servo wind the line in? Just a couple of things to try |
