01-15-2011, 12:11 PM | #1 |
Rock Crawler Join Date: Aug 2009 Location: crawlerado springs
| need a good lipo size for titan12.5t in an scx10 scaler?
do you have any suggestions? i have an old school regular battery in it right now. it worked good for the brushless. but i need more for my titan 12.5 and xl-5. im ready to make the switch to lipo. i want something that is gonna make my titan work to its potential! thanks in advance for the help. i got 175 to spend on a charger and a lipo. will i get a worthy lipo and charger for that? |
01-16-2011, 03:29 AM | #2 |
Quarry Creeper Join Date: May 2009 Location: Under Communist Occupation
A good charger is the Onyx 230, but that will break your budget with the LiPo. With the XL-5, what do you plan to do about the low voltage issue with the LiPo cells? |
01-16-2011, 06:32 AM | #3 |
Since the ESC can handle a 2S LiPO & possibly a 3S (info here... http://www3.towerhobbies.com/cgi-bin...&I=LXVSJ4&P=ML), you could do a Venom ProCharger... (http://www3.towerhobbies.com/cgi-bin...&I=LXUAB8&P=ML) which will charge just about anything and this pack (http://www.cheapbatterypacks.com/?ap...9292&bc_menuid=). Hopefully this helps. BTW, I own 2 of the chargers & 4 of the packs. |
01-16-2011, 10:54 AM | #4 | ||
i went to the LHS and they didnt even have a good selection of lipo charger and balancers. so i went with traxxas power cell, 8.4v series 4 4200mah. it is a nimh. but my 15 min charger works for it and i got alot more power now! thanks again for your help guys!!!! i really appreciate it!!!!!!!! | ||
01-16-2011, 12:16 PM | #5 | |
While some sites (hobby partz?) have great prices, they are "offshore" so I have my doubts on support if you get a "dud" unit. I spend a little more for a USA unit to avoid some of the potential issues. I own a Ice charger for most packs, but own 2 Venom ProChargers to cover LiPO and others. | |
01-16-2011, 12:35 PM | #6 |
ok! thanks for the heads up! ill get a new one asap! the charger i have is a hobbico auto charger 900. the only "dial" on it is the timer its self. trickle charge = 35-75mA fast charge=5 amps max. my old battery was about 10 years old, as is the charger. and its done fine over those 10 years. id say there were a good 4 or 500 charges on my old battery. the charger i have now is a usa model charger. do you have a link to the peak charger? i want to get it just because i know 15min fast charge is not the best way to go.... i dont know how long to charge it on the trickle charge so i have never tried! thanks again for your help!!! |
01-16-2011, 01:21 PM | #7 |
I use one "Ice" charger as well as 2 Venom ProChargers. All 3 do a "peak charge" which is better than a timer. There are lots of choices out there for chargers, but an "off-shore" charger "may" have issues with support if you have a question or issue. If you do LiPO's, a balancer (part of the charger or an external balancer) is worth it to prevent issues. |
01-19-2011, 08:06 PM | #8 | |
Pebble Pounder Join Date: Jan 2011 Location: Rochester
