01-26-2011, 04:20 PM | #1 |
Quarry Creeper Join Date: May 2005 Location: edmonton
| what the heck
so I just wired up my 55 turn motor, and now it goes faster in rev than forward so I switched the wires going to the motors. but there is no change. so how do I get it to run properly
01-26-2011, 04:27 PM | #2 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
With so many variables that we don't know, I doubt many of us can do much....... Give us the specs.....esc, radio, motor, battery, etc......might help us point you to things to try to solve the problem. Later EddieO |
01-26-2011, 04:33 PM | #3 |
sure a 55 turn integy motor 3000 niimh battery esc traxxa XL 5 waterproof radio is a custom traxxas 6 channel pistol grip but before we jump to the radio I have used it with another rig and the throttle worked perfect |
01-26-2011, 04:33 PM | #4 |
I'd suggest calibrating the esc again , but under normal conditions. There is a soft stopper on the trigger when forward (pulling the trigger), so if you calibrated it with a heavy finger and pulled it way back in the case tooo far, then chances are you aren't meeting that set calibration point when just crawiling normally. We are talking about that radio i built correct? |
01-26-2011, 04:34 PM | #5 |
| +1.....I will assume this is a MOA since you stated "motors".
01-26-2011, 04:41 PM | #6 |
Ok, do this.... Connect a battery directly to the motor in the correct polarity......do the wheels rotate correctly and at speed? Now reverse the wires.....does it get faster or slower or stay the same.......if it gets a tad slower or stays the same, I would say the motor is NOT the problem. Which leaves either the ESC or Reciever/Radio as the problem... Start by recalibrating the ESC. Its not uncommon for them to grab neutral at the wrong spot.... Then, once thats done and if your problem is still there.....I would make sure all the radio settings are set correctly.... Just because it worked with one truck, don't assume your radio will just be dialed on the next..........Radios are like woman......just because it worked with one, doesn't mean it will work with another Later EddieO |
01-26-2011, 04:43 PM | #7 |
Quarry Creeper Join Date: Dec 2006 Location: Tasmania
Could be motor timing (endbell advance). Motor timing can be (on most motors) adjusted to alter the timing, so very similar to a distributor on a petrol engine. When you run a motor with 5 degrees advance backwards by reversing the voltage, like you have to on one end of a MOA, it is technically then running 5 degrees of retardation, resulting in "faster in reverse" but poor power and excessive heat and power consumption spinning "forward". How to see if you motor has advance?... Last edited by Badmuthatrucker; 01-26-2011 at 04:46 PM. |
01-26-2011, 05:30 PM | #8 |
man I love this site I recalibrated the esc and checked the motor, think it was a combination of both things the long of the short is it's working and I'm happy thanks every one and yes it was the radio you made, musts a heads up to everyone his radio kicks ass check them out if you want a postal grip with lots of channels later |
01-26-2011, 05:53 PM | #9 | |
when i built yours i was experimenting and i removed the stopper on the trigger, an i ended up replacing with something alot softer. So if pulled hard enough you would get an additional 5-10 percent of throw. because of flexing the stopper back. Thanks for the kind words, right now i'm having a hard time competing with the 4pl though, it will do everything mine can. but its got a screen, so more user friendly..., and same price range, i have had lots interested till i told them 200-250.But i have plans for 3-4 radios, all of which will blow any competion away at the price range. But these are aways out till i can figure out fcc and getting moulds made. Anyways back on topic...Glad you got it figured out | |
