01-26-2011, 08:46 PM | #1 |
Pebble Pounder Join Date: Jan 2011 Location: Rochester
| castle bec causing glitching?
I'm chasing some sort of electrical gremlin on my LNC. It came to me with a stock esc, titan 21T, hsr-5995tg, CC BEC. It's had troubles since I got it, only seeming to get worse with each thing I tried to fix it with. Today I got my HH handwound 35T in it (to rule out the motor being the issue) and it was awful. So I put a TR2 in it that I had.. worked perfect. However, I had to disconnect the BEC when I swapped esc's. I took the stock esc apart to see if it had an visible signs of damage, and there was none, so I put it back together. Just for shits and giggles, I put it back in the rig to see if the problem was still there, but didn't hook up the CC bec.. worked perfect. I haven't gone ahead and reconnected the BEC to see if that's the problem, but it might be. How could it be the problem though? Anyone ever heard of a CC bec CAUSING a problem instead of FIXING a problem? |
01-26-2011, 08:51 PM | #2 |
Pebble Pounder Join Date: Jan 2011 Location: Bakersfield,Ca
Yup,went through the exact same problem and it turned out to be the CC BEC.time to replace it.
01-27-2011, 06:23 PM | #3 |
01-28-2011, 07:23 AM | #4 |
Quarry Creeper Join Date: Mar 2008 Location: richmond
thats what i had to do.. i had my servo power leads connected to my bec,while the servo signal wire was in the rx.. soo basicly my mamba soeed control's bec ran the rx while i had my ccbec wired directly to the battery via speed control plug bypassing the rx and everything running only my 9100t servo.. ran great that way
01-28-2011, 09:16 AM | #5 |
Quarry Creeper Join Date: Jan 2011 Location: 801
Ok time to chime in. I also have glitchy problems but not sure what it is, I was told it was the 2.4mhz am radio rx setup but a friend has the same tx/rx & his is perfect and has no bec. How would I wire my bec up so it still works & fixes the problems? |
01-28-2011, 09:38 AM | #6 | |
If you don't want to snip them, you can also just use a knife or small screwdriver to undo that particular wire that goes into the plug and just fold it back and wrap with electrical tape. When I made mine I took all the wires out of the plug, slipped on a piece of shrink tubing, put it back together and put the shrink tube over the wire I took out and shrunk it down. Go to this thread BEC hook-up help to see a good picture of what I'm describing. t3rry shows a good pic of it. Last edited by marvinbeaverdip; 01-28-2011 at 09:41 AM. Reason: error | |
01-28-2011, 09:44 AM | #7 |
01-28-2011, 09:54 AM | #8 |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
a simple (modified) y harness will fix you up. |
