01-27-2011, 12:38 PM | #1 |
Pebble Pounder Join Date: May 2005 Location: Long Island NY
| 4PK Help
Ok this will probably be painless for you guys but I am lost.. I am running a XL-5 and a 4PK.. Prior to installing the 4PK I had my Airtronics FHSS installed and everything worked fine.. After installing the 4PK I am having issues. The Steering works but I cannot get the ESC to program or work correctly. Anyone have any instructions on how or what to adjust/set up?? Does any of the EPA/Sub Trim etc need to be adjusted, zero'd out? I am guessing that the ESC needs to be plugged into the 4ch/B but I just cant figure it out.. Any help guys?? Thanks |
01-27-2011, 07:16 PM | #2 |
I wanna be Dave Join Date: Sep 2006 Location: Stuck on a Rig in the middle of nowhere Utah.
The ESC gets plugged into the #2 channel and Steering is #1. I bet that will solve your problems. Just make sure your trim is set to ZERO first and then program the ESC to the Radio. You might have to reverse the #2 channel but you won't know that until you try the programming. |
01-27-2011, 07:47 PM | #3 | |
Thanks man after about 2 hrs of playing with this freaking thing I figured it out, would have helped to plug the ESC into Ch#2 like you mentioned Got it all working now, even the Ramtech Leds turn on and off | |
