01-27-2011, 07:01 PM | #1 |
Rock Crawler Join Date: Nov 2008 Location: Maple Ridge, BC, CANADA
| traxxas xl5---can u use 2s or 3s on them?
as stated above....can a traxxas xl5(waterproof) work with a 2s or 3s batt? I have a rooster right now on a 3s with a voltage cut off....but I know the rooster can handle 2s no problems..... can the xl5 do the same? |
01-27-2011, 07:32 PM | #2 |
Rock Crawler Join Date: Sep 2008 Location: Delta B.C.
its fine on 2s..no lvc though..not rated for 3s, but i know a few that do run them on 3s with a castle bec with no issues..actually 4mods does for sure..and were talkin crawler type motors..im not telling anyone to do it because its not rated for it, ..maybee send 4mods a pm on cc and ask what motor he,s running
01-27-2011, 07:44 PM | #3 |
Rock Crawler Join Date: Aug 2008 Location: Strugglin
I've ran one for about a year on 3s and no issues at all. Never really gets warm. But the LVC is a issue.
01-28-2011, 12:10 AM | #4 |
RCC Addict Join Date: May 2010 Location: Los Altos, California
you can run 2s, but ive heard people use 3s too.. however, you will need a Low voltage cut-off
01-28-2011, 12:27 AM | #5 |
thanks guys.... and will do voncold |
01-28-2011, 12:39 AM | #6 |
Pebble Pounder Join Date: May 2010 Location: Ringgold GA USA
I know that the new xl-5's have a 2s lvd and the older ones dont and they say that there not compatable with a novak lvc . I wonder if a guy got a newer one and wanted to run 3s if it would work with the novak lvc ?
01-28-2011, 01:10 AM | #7 | |
Pebble Pounder Join Date: Mar 2010 Location: PHX
http://www.teamnovak.com/tech_info/i...tes/index.html The Novak Smart-Stop 2S Li-Po Cut-Off Module (Novak #5470) is not compatible with the blue-cased Traxxas XL-5 ESC (Traxxas #3018X) that is included with the Traxxas Slash 1/10 2WD Short Course Racing Truck (Traxxas #5805). This module may or may not be compatible with the original, gold-cased Traxxas XL-5 ESC (Traxxas #301. Novak is researching this issue to determine if an update can be made to the module or if a separate module can be offered for this application. I wish I would have found this before I wasted my money a year ago. | |
01-30-2011, 07:06 PM | #8 |
Ok so i got a losi 2s esc out of a night crawler. would anyone happen to know if it can handel 3s with the novak lvc? iam running it in a honcho with either a 15 or 20t pinion 87t spur and stock 27t motor.
01-30-2011, 08:21 PM | #9 |
| if its not rated for 3s i,d say dont do it even with an external bec..worm gear trucks put alot more strain on the electronics..and i dont have huge faith in losi esc,s..you can only get away with the running an extra cell by adding a bec on a few esc,s and definatly will not work on all
02-01-2011, 12:50 AM | #10 |
I know the worms are killer on all the electronics. but i have mine in a honcho and it has alot less friction . Iam only running the losi esc because the stock honcho one is junk. i did do a very short test yesterday with a 3s lipo in it a big big upgrade if i can ever find out if i put the novak low voltage cut off on it that it will be ok . There would be so many more stupid people in the world if we all had a million dollars because then there would be know need for all the extra elbow grease. |
02-01-2011, 05:13 PM | #11 |
Rock Crawler Join Date: Jul 2009 Location: greeley
| If you have $70 spare I'd try 3 cells on it. I doubt it would burn up your LNC if the esc. smokes.
02-01-2011, 05:47 PM | #12 |
02-03-2011, 11:32 PM | #13 |
Think iam just gonna run it 2s till i get something elese then iam gonna 3s the crap out of it. Just huck it
