01-28-2011, 10:43 AM | #1 |
Quarry Creeper Join Date: Mar 2009 Location: moses lake wa
| Help problem with my mamba micro esc
I have a problem with my mamba micro esc. when I put this in my 1.9 and give it throttle fast or really anything but very slow input the servo cranks to one side and then returns to center, I'm running a BEC from the batt to the servo and powering the rx by the esc. I tried a different servo, batt, BEC, and receiver also programed the esc and updated it. Nothing helped. I ended up swapping the esc and fixed the problem so it has to be the esc. Anyone has an idea how to fix this? |
01-28-2011, 10:58 AM | #2 |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
Chad had the same problem with his Losi at the nats. Battery was the problem. |
01-28-2011, 12:21 PM | #3 |
Can you give us a little more info on exactly how you have it wired...
01-28-2011, 03:17 PM | #4 |
RCC Addict Join Date: Dec 2009 Location: Newcastle, Australia
My son had the same problem in his rig after going brushless, never figured out what caused it but it really shouldn't of happened when servo was hard wired to the bec... Anyway run your bec to your rx and it fixes it |
01-28-2011, 08:16 PM | #5 |
I'm running my BEC though my servo to battery as in pos and neg of BEC and servo together and BEC hooked to battery leads. I switched batteries didn't help.the reason I didn't hook the BEC from batt to rx is I didn't want to over power my rx with 7 volts |
01-28-2011, 08:52 PM | #6 |
Yep the way you have it wired is the way we had trouble.. are you sure the rx cant handle 7v? ive got 7.4v running to both my specktron and nomadio rx's no probs One thing i thought might be causing it is the built in bec of the esc, maybe it was sending some signal to the rx when i applied throtle causing the servo to play up.. i did think of using a bec to the rx and a bec to the servo to see if the servo still played up but the bec to the rx powering the lot fixed it. I also remembered having this problem on my losi esc, truned out the CC bec didnt want to work with it, i tried a few bec's no change, tried bec to rx & servo but no change.. the only fix for that one was changing to a HiModel bec |
01-28-2011, 10:04 PM | #7 | |
Nomadio reciever on 7 volts | |
01-28-2011, 11:32 PM | #8 |
