02-01-2011, 04:35 PM | #1 |
Quarry Creeper Join Date: Jun 2010 Location: Ravenna/ Sault Ste. Marie
| Hesitant Rooster
hey guys i have a rooster crawle esc and a tekin 55t (not sure hand or machine wound) and when im crawling and driveing it will go good for a while then like pause and pick up again... and sometimes this has happened on obstacle and the rig will slide back down and i have to get my line again. any suggestions? heres my wire setup: twisted black red and white wire-esc white-antenna flat black red and white-servo twisted red and black (only)-on/off switch blue and yellow-to motor black and red-battery (yes the last two were self explanatory but i figured id say em anyway) |
02-01-2011, 04:45 PM | #2 |
Pebble Pounder Join Date: Dec 2005 Location: Coopersville,MI.
What is the spring around your antenna wire? And you need to run the antenna away from everything else and maybe up a little. I put my antenna up inside my JK and no more glitches and that was all I did.
02-01-2011, 04:49 PM | #3 |
that keeps the wire from getting caughtin anything and ripped off. and i tried that it helped a litttle but it was still under the body so maybe ill try to run it up out of the body..
02-01-2011, 04:52 PM | #4 |
I'm sure the spring around it is not helping anything. You did not cut your antenna wire did you? You need to just save and get a 2.4Ghz radio and problem solved! When did it start doing it? It was not that bad before. |
02-01-2011, 04:55 PM | #5 |
yea i should try that too, and its been doing it ever since i got it. it just decides when its going to do it or not,and im going to try for a 2.4 i can find em cheap but im going to build a crawler at my moms first
