02-03-2011, 12:50 AM | #1 |
| VXL with BEC?
Anyone know if the VXL 3s esc has an internal BEC? IF it does, what are it's Volts/Amp ratigs? I assume it can power a 200 oz steering and a shift servo? What about powering a JR 9100T? Otherwise, i assume you are running a BEC with it? Last edited by TSK; 02-11-2011 at 02:34 PM. |
02-11-2011, 02:40 PM | #2 | |
It's in here somewhere: Quote:
02-11-2011, 03:44 PM | #3 |
| Thanks. All the spec sheets i found left me in the dark regarding the BEC. Doens't look like it has enough current to support much.... but I'd be using 3s... So if i want to test the BEC current on 3s, do i just use a voltmeter on the red rx lead? Or should i just direct wire a CC BEC to the 9100t? |
02-11-2011, 04:03 PM | #4 | |
I think the internal BEC will let you down when you are running 3S, but hopefully I'm wrong. Quote:
02-11-2011, 05:51 PM | #5 | |
