02-05-2011, 05:02 PM | #1 |
Rock Stacker Join Date: Oct 2009 Location: Huntsville
| motor question
Which setup would have the longest run time. I'm running an axial trans with axial axles and 2.2 mudslingers. I'm looking for runtime, should I run an Integy 35 turn lathe with a 16-20 tooth pinion or a stock axial or hpi 27 turn with a 13 tooth pinion? the pinion could change not absolutely dead set on those.
02-05-2011, 05:19 PM | #2 | |
Rock Crawler Join Date: Dec 2010 Location: Piedmont, SC
02-05-2011, 07:02 PM | #3 |
Yeah really, for runtime go 2 cell lipo on 55t. The 35t should give you more runtime than the 27t, especially considering you can run it at low timing advance.
02-07-2011, 08:07 PM | #4 |
Okay, I've got an Integy 65 turn (I'll have to double check I think it is a lathe motor). My buddy gave it to me since he changed his out to a Brood motor. The motor was put in a cc-01 with 1 battery pack run down on it. Is there anything I can do to pep it up any. It seemed a little weak in his cc-01.
02-07-2011, 08:25 PM | #5 |
Add voltage. Lots of it.
02-07-2011, 08:48 PM | #6 |
I've been reading some of the info on here about the tuning and maintenance of brushed motors. Should I find somebody to true it up on a lathe? What about tuning with brushes and timing? Endbell alignment ? So much info, it can be easily overwhelming.
02-07-2011, 08:58 PM | #7 |
First you need a motor that spins fast enough to make the power you need. Either a faster wind or a higher voltage. Then you can make the last 10% with tuning. While tuning is always a good idea, I don't think it will get you far enough with a 65t on probably 6 cell nimh.
02-07-2011, 09:14 PM | #8 |
Okay Thanks |
