02-10-2011, 08:01 PM | #1 |
Rock Stacker Join Date: Jan 2010 Location: hamilton
| Goat 3S with 18.5 motor getting to hot
Im running a goat and 18.5 and the motor gets extremely hot. I have no driveline bind if you take the pinion off the wheels free spin for a while. Im running 12 and a 89 and i have the lowest gears made for the axles. Has anyone else had this problem? I starting to think maybe im running to much drag brake i dunno.
02-10-2011, 08:10 PM | #2 |
Rock Crawler Join Date: Jun 2009 Location: summertown
Wat kind of crawler, Battery type, do you have the pinion and spur mesh to tight??? a little more info will provide more answers |
02-10-2011, 08:23 PM | #3 |
The gear mesh is perfect just a little play in between the spur and pinion. Its a scx with just a nimh it gets exesively hot. I put a 3s in it and in about 1 min of easy running it was almost to meltdown stage. and with the stick pack i have checked it with a temp gun and it at 190deg.
02-10-2011, 08:31 PM | #4 |
Newbie Join Date: Jan 2008 Location: Gibson BC
Hey there. I have a goat 2S with the 18.5,and i run a 3cell with a cc bec. But i turned up my drag brake and it got really hot just sitting there on the floor.so turn it back to setting #3 and all went back to normal. |
02-10-2011, 08:31 PM | #5 |
Newbie Join Date: Jan 2011 Location: Las Vegas
02-10-2011, 09:16 PM | #6 |
| Same here on 2s with the drag brake maxed, just sitting there on flat ground would get extremely hot. I find settings around three easier to drive with the way the goat drag works also, instead of freewheeling down hill I can let it creep on the brake.
02-10-2011, 09:21 PM | #7 |
thanks for the help going reprogram it right now |
02-10-2011, 10:09 PM | #8 |
Problem solved just ran my 3s and it only got warm |
