02-12-2011, 11:36 AM | #1 |
Rock Crawler Join Date: Nov 2010 Location: Denver
| How to convert tx from AA to LiPo?
Are there any write ups on how to convert my tx from the 8 AA batteries to A single small LiPo battery? Any and all direction on this is greatly appreciated. Thanks |
02-12-2011, 12:07 PM | #2 |
A lot depends on how many AA's your TX needs. While I usually run regular (alkaline) batteries, I have used "rechargables" but I am concerned that they are ~1.2VPC vs. 1.5VPC (BTW, VPC = Volts Per Cell), thus I start off a bit low for TX voltage, so even when fully charged you are on the low end for total voltage. |
02-12-2011, 12:25 PM | #3 | |
02-12-2011, 01:03 PM | #4 |
02-12-2011, 01:06 PM | #5 |
02-12-2011, 01:31 PM | #6 |
Newbie Join Date: Dec 2008 Location: Augsburg
I have a DX3R with 4 Eneloops, no Problems at all It depends on the transmitter. If you want to change your AA to LiPo, have a look in ebay or ask your local dealer. There are a lot of special transmitter lipos on the market. Yours, Martin |
02-12-2011, 01:58 PM | #7 |
Yes AA Alkalines start out at 1.5V but the voltage drops off quickly as they are consumed. NiMH starting at a lower voltage will actually maintain that voltage before it drops off. I have been using a 3 cell lipo 2600mah in my 3PKS for about four to five years and never had any problems and the voltage is more stable too. Recently I switched to a Spektrum DX3R and the 4 Alkaline AAs would last about 8 to 10 hours. I use NiMH AAs 2200mah and they seem to last about the same but the voltage is more stable, until it falls off and then it's replace or recharge ASAP. I keep 4 fresh Alkaline AAs in my radio bag just in case. |
02-12-2011, 02:30 PM | #8 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
This is where I did my 4pk. Not exactly what your looking for, but it gets you in the ballpark. http://www.rccrawler.com/forum/showt...po#post2807358 |
02-14-2011, 09:18 AM | #9 |
What tx do you have? a 3s lipo should work fine as a 8AA replacement, just get some sort of low voltage alarm or cut-off |
02-14-2011, 10:22 AM | #10 |
Rock Stacker Join Date: Dec 2008 Location: CARO
may want to check some of the losi lipos some of those have a cutt-off built in but if you add the voltage of those 8 aa youll get 11.1v
02-14-2011, 11:14 AM | #11 |
Pebble Pounder Join Date: Jun 2009 Location: Belle Fourche
I thought about a small 3 cell lipo for my 4pl, Use a Bec to Regulate it down and have a ton of runtime |
02-14-2011, 01:00 PM | #12 | |
I would use a 2cell lipo and a voltage regulator to bring it down to 6V. You will still get all the run time from a 2S of equal capacity. | |
02-15-2011, 01:28 AM | #13 |
Rock Crawler Join Date: Jul 2009 Location: greeley
| in the 4pl instruction manual it says: WARNING: Do not use LiPo It creates to much voltage. If not 4 "aa" use a 2 cell life or 5 cell rechageable. Use a LiPo if ya want though
02-15-2011, 07:30 PM | #14 |
Hence the reason for useing a Bec, set the bec at 6 volts and never have to worry about the voltage, you could use a 6 cell lipo if you want will not make a difference
02-15-2011, 07:56 PM | #15 |
RCC Addict Join Date: Jan 2008 Location: Mount Juliet
For the 4pl, hobbico makes a 2 cell LiFe pack that fits perfectly in the bottom of the 4pl, and is the correct voltage when you change the battery setting in the 4pl. I have it....and it fits like a dream. No BEC is needed. I got it for $34 shipped. http://www.gonitrohobbies.com/Hobbic...p/hcam6520.htm |
02-15-2011, 08:48 PM | #16 |
I have a FlySky GTB3 and it does have a setting on it to see what voltage is left in the battery. So I suppose I can just keep an eye on that and change batteries before it dies. What is the voltage that you want to keep a LiPo above? |
02-15-2011, 08:50 PM | #17 |
How about a 1 cell lipo. With some circuitry that will bump it up to 5v's and have built in charge/discharge protection. Sound interesting?
02-15-2011, 08:58 PM | #18 | |
Rock Crawler Join Date: Nov 2005 Location: Rock-throwing country
3.0 volts per cell. I myself don't like to see them go under 3.5v Most lipo cut-off start at 3.3v | |
02-16-2011, 01:49 AM | #19 | |
Since the LiFe is designed for it as a battery upgrade. Its just plug and play. Don't really see any advantage to using a LiPo then regulating the voltage but have fun. | |
02-16-2011, 08:18 AM | #20 |
