02-12-2011, 03:33 PM | #1 |
Pebble Pounder Join Date: Aug 2009 Location: Lost in what was America
| Castle ESC up in Smoke!
So went to drive the truck today and got maybe 20' on a rock pile when the ESC sounded like it cut off and then back on. The truck quit moving and then appeared the white smoke. When I looked at the esc the whole side of the case looks melted on the side where the negative wire goes into the case.Here are the specs.... Sidewinder SCT ESC 3s lipo CCBEC holmes hobby outrunner brushless I think its the stock axial spur gear with a 21 tooth pinion? Anyone have any ideas what may have caused this? I just got the ESC, the BEC, and the lipo's. I am stunned. Gonna call castle on monday I guess..... Last edited by silverback4jack; 02-12-2011 at 04:39 PM. Reason: added |
02-13-2011, 08:21 AM | #2 |
Infant death, Castle will take care of you.
02-13-2011, 09:16 AM | #3 | |
RCC Addict Join Date: Sep 2006 Location: Depew
02-13-2011, 10:06 AM | #4 |
I figured they would take care of it but, I just couldnt figure out why it happened with the setup I had.
02-14-2011, 10:20 AM | #5 |
Ok so i called castle and they told me it sounds like a battery problem. They told me to send it in and they would look at it. When I told them I was runnin a holmes hobby outrunner motor they said they didnt know if their ESC could handle a brushless outrunner motor. So i am gonna email some pics to HH and see if they can give me some specs on the older outrunner that i am running. The weird thing is the motor was being ran on another sidewinder befor with no problems. When it rains it pours!
02-14-2011, 10:25 AM | #6 |
It should be fine with my outrunner, most likely a revolver or Crawlmaster. Send some pics of the mount face or the rear and I can send motor information to Castle if needed.
02-14-2011, 10:26 AM | #7 |
Rock Stacker Join Date: Dec 2008 Location: CARO
3s could be to much depends on the specs of your out runner
02-14-2011, 03:19 PM | #8 |
Thanks John i am gonna try and get some pics when i get home of the motor. I dont think its the revolver. Its silver and just about all of the writing is wore off the label. I hope the 3s isnt too much. I dont think yhe outrunner is over 4000kv. The esc says it will handle 3s on a motor lower than 4600kv i think. |
02-14-2011, 06:06 PM | #9 |
Newbie Join Date: Feb 2011 Location: canada
whats the difference between the sidewinder and sidewinder sct?
02-14-2011, 07:55 PM | #10 |
When i called castle they said the motor that comes with the esc was the only difference. All programming was the same and still able to have the crawler drag brake.
02-16-2011, 05:43 AM | #11 |
Sorry for the delay on the pics. Been hectic around here. Any help identifing and specs would be great. |
02-16-2011, 06:20 AM | #12 |
Rock Crawler Join Date: Dec 2005 Location: West Omaha
21 tooth pinion is a bit high do ya think?
02-16-2011, 07:39 AM | #13 |
Ah, an oldie. Revolver 2, 2212 frame if I recall correctly. No way that caused the ESC to go up, it is a tiny motor.
02-16-2011, 09:34 AM | #14 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
what would make that SW go south....other threads i'v read they can handle higher then 4s batt's....when i talked to castle bout my problem i have john from posting in your thread the new v2 isn't much different from orig SW....the SCT SW kit is the v2 SW from what CC told me....plus they have motor combo kits out with the 5700kv or 5400kv forget which it is at this moment....the 21t pinion gear he said he has would just add wheel speed to his crawler.........bob .... |
02-16-2011, 09:41 AM | #15 |
Just a bad day for the controller. Sometimes chit happens.
02-16-2011, 12:43 PM | #16 |
I wanna be Dave Join Date: Jul 2006 Location: Moscow Mills MO
Pinion. Get a 12-14t. You don't have much gear reduction going on. What tires you running? |
02-16-2011, 12:50 PM | #17 |
RCC Addict Join Date: Jun 2009 Location: California
I run a Sidewinder on 4S with Holmes 1100kv outrunner...Sweet scaler setup. It defiantly was not your motor that caused the problem. My sidewinder is cool to the touch after bashing with a 4S, ya just got unlucky..send it back. Castle will hook ya up. |
02-16-2011, 07:14 PM | #18 |
Thanks for the input guys. I am trying the 21 pinion to boost wheel speed. Hasnt really been driven much to say a lot about it. It is nice not to creep from one spot to the next.
02-16-2011, 07:56 PM | #19 |
The 21t pinion seems weird, but if you didn't change the spur I guess it's just like changing a few teeth on the spur and a couple on the pinion. The 21 will cause the ESC and motor to have to work harder when crawling. I still don't think it's enough to cause the ESC to let go though. I hope they help you out on this one...it seems like a faulty unit.
02-18-2011, 05:45 AM | #20 |
I mailed it to castle yesterday so now i just wait. Hey john do you have any specs on that motor as far as what kv it might would be? Thanks again for all of the help. |
