02-16-2011, 05:34 PM | #1 |
Rock Stacker Join Date: Nov 2007 Location: Dover, De
| Novak M2 Dig
Has anyone tried the Novak M2 dig in the XR-10 yet? Looking at purchasing one, but wanted to know if its a good fit in the rig first! I am not a heavy comp guy yet, just looking to do it right the first time.
02-16-2011, 05:50 PM | #2 |
Moved to electronics.
02-16-2011, 05:51 PM | #3 |
Pebble Pounder Join Date: Oct 2007 Location: on top of a rock
If you want to do it right the first time, then get a Punk Dig and a good ESC of your choice. Lots of people have had problems with the old technology used in the M2
02-16-2011, 05:57 PM | #4 |
FXR and punk dig?
02-16-2011, 06:05 PM | #5 |
| To "do it right" you would be looking at a dual ESC setup. A FXR and punk is just a reliable less capable option.
02-16-2011, 06:07 PM | #6 |
02-16-2011, 06:12 PM | #7 |
02-16-2011, 07:08 PM | #8 |
Will do, thanks!
02-16-2011, 09:59 PM | #9 |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
if i were to do it over, i'd go dual mamba micro... m2 is not a good option at this time, and fxr's are more expensive than they need to be.
02-16-2011, 11:05 PM | #10 |
02-16-2011, 11:22 PM | #11 |
Pebble Pounder Join Date: Mar 2010 Location: Bend
| 1/18 micro's
Yes thats what he's refering too
02-16-2011, 11:29 PM | #12 |
Not to sound like a total newb...would they get wired like the fxr's and can you use brushed motors with them? I ask about the wiring because that's all people show it seems!
02-17-2011, 03:52 AM | #13 | |
Quarry Creeper Join Date: Jan 2010 Location: USA
Also, if you already have the radio you were going to use with the M2, please check check this out: http://wantasummit.com/DualESC.aspx Depending on what you already have, it could either be your solution or part of an upgrade path. | |
02-17-2011, 06:38 PM | #14 | |
Right now the M2 has one significant problem, the proportional control just doesn't work. But, it is a good three-position dig/ESC. I have run three comps with it running on the 1.2v firmware and have had no problems. The drag and dig brakes hold very well when you have the settings maxxed out. It has a nice compact foot-print and its easy to install and setup. With that said, if you have the funds to go with a dual ESC setup, you might want to go with that. | |
02-17-2011, 08:37 PM | #15 |
Not sure which way to go...thats why its been a work in progress since October!
02-17-2011, 08:49 PM | #16 | |
I switched to dual FXRs and so far I'm very pleased with the set up. Smoother, stronger and better control, what more could you ask for. | |
02-17-2011, 10:22 PM | #17 | |
You have a good smatterring of people giving you what they know. If you have a local club, I recommend running what the club drivers are, they will be able to support you better with what ever system you decided on. | |
02-18-2011, 01:43 AM | #18 | |
02-21-2011, 02:38 PM | #19 | |
Quarry Creeper Join Date: Dec 2008 Location: other side of the track,the bad side
