02-16-2011, 08:47 PM | #1 |
Rock Stacker Join Date: Oct 2010 Location: San Antonio
| Cobalt Puller motor?
When using a cobalt puller motor 10T with a 3S lipo what is a good pinion to use to have good torque and moderate speed? This would be for a stock axial trany.
02-16-2011, 08:50 PM | #2 |
I don't know much about axial trannies, but try a 14t. Seems decent with a 45t novak on 2s, so i'm sure it rip with a 10t puller, the puller gots loads of torque, so its more of how much speed you want...
02-16-2011, 10:50 PM | #3 |
If you are running the stock 87 tooth spur, the biggest pinion you should run with is probably a 14-15 tooth while on 3s. If you drop down to a 2s, you can probably go up to 18-20 tooth on the pinion (with the 87 tooth spur.) The motor should stay warm (100*) just keep an eye on the temp of the motor and use that as your gauge. |
02-17-2011, 07:49 AM | #4 |
Ditto, start with a 14t. You can gear as high as you want if the motor temp stays under 160f.
02-17-2011, 08:13 AM | #5 |
Nice thanks for the info. |
