02-18-2011, 08:37 PM | #1 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
| DX3R charge port question/issue
I finaly got around to making a charge adapter for the DX3R, I know that its polarity sensitive, checked it with my voltmeter aswell as my charger (reverse polarity protection) so I picked up some 1.5v 2000mah AA's and slam them in and it was showing good voltage so I was happy, I wasn't convinced they were fully charged from the factory so I hooked it up and set my charger to NiMH 0.5a charge rate. everything was going smooth, sat and charged for about 3 min, then I heard a cell fail (i'm pretty sure 3 of the 4 failed) I cleaned the battery area of the radio best I could and slapped in some normal AA's to make sure it was still working wich it is, I just don't know what I could have done wrong. the only thing that comes to mind is over charging the cells but it should have cut off at peak before a failure the question I guess is, are you guys using certain battery's when you use the charge port? the charger I was using is a Electrify Triton EQ if it matters. Last edited by fred0000; 02-18-2011 at 08:43 PM. |
02-18-2011, 08:53 PM | #2 |
Debunking old stereotypes Join Date: Feb 2006 Location: 1st and Amistad
To be honest with you, the DX3R is the easiest radio on batteries I've ever owned. I get at least the 1st half of the season (6 comps) plus scaler time in with 1 set of regular alkaline batteries. I never saw a need to use the charge port and rechargeables.
02-18-2011, 08:57 PM | #3 | |
02-18-2011, 09:07 PM | #4 |
I use rechargables but charge them externally. I have a couple AA/AAA chargers so I never bothered making one to plug in. BTW: the 2200 mah AAs I use hold their voltage steady a lot longer than alkalines. It'll stay at 4.8 to 4.9 volts for a couple crawl (two classes) and race (three classes) days. |
02-18-2011, 09:10 PM | #5 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
i read a thread bout two years ago, but i'm not sure but i think the 1/8" plug that goes in the plug there the normal positive part of the plug should be the negitive with the DX3R radio for some reason....i could be wrong and check before trying that....that's the reason i didn't go chargables in mine was the reverse poles on the plug it needed to be....like i said i could be wrong so double check before trying it that way, check there website and/or even call spektrum.......bob .... |
02-18-2011, 09:10 PM | #6 | |
02-18-2011, 09:20 PM | #7 | |
02-18-2011, 09:22 PM | #8 | |
02-20-2011, 04:04 PM | #9 |
i've decided to try it again, this time i'm going to wait and run down the batterys and try a full charge instead of "peaking" them. i'll be charging them in this the 1st couple times to see how it goes, I don't want all that crap in my radio again. |
