02-19-2011, 12:58 PM | #1 |
Quarry Creeper Join Date: Dec 2008 Location: Punta Gorda, Flo-rida
| Motor issues
So i am currently having issues with 2 motors right now the first is a 45 turn and the second is a 35 turn. The 45 turn is about 6 months old and has had about 100 packs through it, about 60 packs into it it was rebuilt with new brushes and the comm was lathed down. The 35 turn had about 6 packs through it, both have the same issue. When i move the throttle forward they do nothing, unless i help them spin ( start to spin the tires) once they are going they have as much torque as they always have but the second i let off and start up again they dont move. I have sanded down the brushes in case they where sticking and the springs are applying plenty of force. From the little i know about motors this doesnt sound like i burnt up the motor but something else. I hope all of this made sense. Thanks in advance |
02-19-2011, 01:11 PM | #2 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
If you have any plugs in the motor wires, remove or replace them. I have seen plugs cause this. IF that and a rebuild don't work, you more than likely have what I've coined as stalling out the arm. Which means you've basically shorted it internally. Later EddieO |
02-19-2011, 01:14 PM | #3 |
| what are the most common ways a person shorts out thier motor?
02-19-2011, 01:18 PM | #4 | |
Same question as rock hard | |
02-19-2011, 01:24 PM | #5 |
| This indicates to me they need another cut and clean job.
02-19-2011, 01:26 PM | #6 |
Excessive amp draw 99% of the time.....some times you gotta just take the penalty instead of just yanking on the trigger... No motor is immune to it either...doesn't matter who makes it. Also, the more voltage you got, the more damage you can do.....I very rarely see it on 2s trucks.... Later EddieO |
02-19-2011, 01:30 PM | #7 | |
Good to know.. will this lead to a blown wind at times,or melt the solder clean off the arm? | |
02-19-2011, 01:32 PM | #8 | |
02-19-2011, 01:42 PM | #9 |
Hmm,you say that the 45t had 100 packs on em with no issue till recently I guess,and now you have a problem,and its showing up in the 35t too,shortly after they was installed. was they (bad motors) both from the same axle? |
02-19-2011, 01:43 PM | #10 |
| Nope one was only a losi moa (35t) the other was on a berg (45t)
02-19-2011, 01:52 PM | #11 |
are you sure the brushes are making good contact? I have seen a brush lead become tight and then the spring is unable to push it enouogh to get good contact with the comm. When this happens a little push is all it takes and she will go,the brush will continue to wear and thr problem will escelate. I have seen the brush leads soldered in a manner where they have very little slack to begine with. |
02-19-2011, 02:09 PM | #12 |
I've seen losis smoke motors in a living room.......they are by far the hardest axles on a motor..... Your arm is the problem. You cannot really fry an endbell like an arm..... It doesn't really blow the solder off that I have seen.......I've only had it happen to 4 of my arms since I've been home, but I've seen quite a few from other companies....I have not noticed the solder coming undone. I appears to be some type of short internally. I am gonna unwind the arms I've kept to see if I can figure out exactly what its doing...certainly never anything we saw in racing really. Later EddieO |
02-19-2011, 02:42 PM | #13 |
I just checked both motors and pushing on the brushes does nothing. I know losi axles are not easy on motors but after buying the motors running them for 20-30 minutes and having issues with the rear motor i took it off and contacted holmes i shipped the old one back and he checked out the motor but unsure what he did and nothing had changed. I bought a $20 integy motor and ran it for 6 months and stalled it out a few times with no issues, never maintained and it finally lost enough torque that i replaced it. After having that issue i have since just bought cheap motors and have had no issues in any of the crawlers they have been in (losi moa, xr10, berg). Is it possible that you sacrifice reliability for torque when comes to these expensive high end motors. I was hoping to not have to buy another set of integys but it looks like i will. Before i start to sound like an integy fanatic i would like to say that the holmes motors have incredible torque but at $120 for a set of motors, its difficult for me to buy one with the experiences that i have had with highend motors. Last edited by paintballer9876; 02-19-2011 at 02:58 PM. |
02-19-2011, 03:33 PM | #14 |
I've seen a LOT of smoked integys.....they are not immune either. One thing to point out with the integys, is that because of the way they are built.....other stuff on the motor will give out before you can do certain types of damage, where as a handwound motor will hold up... Kinda a comparison of what I mean.......your brakes may be good up to 200 mph, but your tires are only rated to 190...they will give long before your brakes will, but put 250 mph tires on....now your brakes can give.... I know its a dumb example......but this is whats happening in a lot of the handwounds that go boom, while an Integy appears to keepion ticking.... Later EddieO |
02-19-2011, 03:59 PM | #15 | |
Thanks | |
02-19-2011, 04:07 PM | #16 |
Like I said though......fry a $20-$30 integy.....spend another $20-$30, as I don't know if they sell replacement arms......they may though. I would guess they would be over $10 if they did. Fry a handwound arm, spend $30, get replacement. It really ends up a wash once you are past the initial purchase price. As for putting handwound arms in integys, I do it all the time for customers. Probably 50% of my arm only sales go into integy based motors. Any 7.5mm comm arm works.... Integy magnets are all over the map......so its hard to say which is which magnet in them. They typically do have weaker magnets, especially in the $20 lathe motors.....weaker magnets do tend to provide smoother start up though, its your drag brake and torque that suffer. That being said, a handwound arm is still a big upgrade for them....I've had reports of people winning comps with my arms in integy cans. Later EddieO |
02-19-2011, 04:16 PM | #17 | |
My other holmes motors will need to be fixed so the option on your website for $35 is what you where talking about before correct? The com is already lathed down so its nice and round so there wouldnt be much to put in an armature, some brushes and springs into it or am i missing something. Thanks for all the help rock hard and EddieO. | |
02-19-2011, 06:36 PM | #18 |
I have found that these premature dead arms are mostly coming from rear motors. 35t are certainly more susceptible than 45t to the event, although I can't say it is often occurring. The best I can tell it is either the comm gap getting too wide from arcing, or a bad leg. More happen with laydown brushes than with standup, by far. Out of the last 1000 motors I recorded 5 premature deaths, yours being the only standup hood IIRC paintballer. You say you sent it in to me, but the stalling came back after I returned it. Did you contact me again about the issue? If not, I would like to get the arm back to see why it is happening since my fix didn't last. Sounds like I need to send you a new arm if you only got 6 runs from it. |
02-19-2011, 08:54 PM | #19 | |
Thanks again to everyone that has helped with my issue. | |
02-19-2011, 09:43 PM | #20 |
Yep, the armature will be a drop in replacement besides getting the shimming right.
