02-20-2011, 12:52 PM | #1 |
Rock Crawler Join Date: Nov 2010 Location: Denver
| Adding a second rx to a tx?
I am building a second rig and I am curious if I can simply add a second rx to my tx and program it to control them separately? I have a FlySky FS-GT3B Digital 3ch 2.4ghz TX what is the process for adding a second rx? The tx says it can control up to 10 different vehicles, but how do you do it? Thanks |
02-20-2011, 12:58 PM | #2 |
Each receiver will require a new model profile on the radio. I would suggest reading through the radio manual for setup info...
02-20-2011, 02:37 PM | #3 |
its very easy to do i run 4 different trucks with mine all you need is extra rx,s . read the manual it will tell you how to do it SUPER EASY |
02-20-2011, 04:43 PM | #4 |
Ok, thanks folks. Is this what I hear when people say "bind" or "binding"? Is that what I should look for in the manual? Thanks |
02-20-2011, 04:50 PM | #5 | |
The TX will hold RX & model (rig) info. You just need to tell it which RX you are using and it will let you select which rig you are set up for. "Binding" is a term for some brand radios. It tells the TX which RX you are using. Since I use a "real radio" (Futaba) I don't have to bind. | |
