02-21-2011, 07:05 PM | #1 |
Newbie Join Date: Jan 2011 Location: West Point
| Glitchy Crawler
I had all these electronics set up on a scaler. Now I got an ax10 roller and moved them over. I built an aluminum top to put the esc and receiver on and a aluminum battery tray on the front. It works good but it is glitchy could it be the aluminum causing the problems or could it be that my electronic are too close? Any reccomendations are great I will try to get pics up by tomorrow. thanks |
02-21-2011, 09:02 PM | #2 |
Pebble Pounder Join Date: Jun 2010 Location: ocala
Could be either of the mentioned, try to keep the power wires away from the servo wires. I'm running dual fxrs in a bully with the receiver right next to my esc's. Also you want to make sure that any material aluminum, carbon fiber exc. are not moving and are attached securing. Also a bad servo will make a vehicle glitch. If you have a spare you might try that.
02-22-2011, 09:52 AM | #3 |
Ok thanks for the advice I will try messing with it this evening and let you know what I find.
