02-26-2011, 02:40 PM | #1 |
Newbie Join Date: Feb 2011 Location: Kansas City
| problems with steering and throttle, beyond my knowledge
i need help, i just got a scx10 TR to join the scaler world and when i try to turn sharp, left or right, it either A; jerks and twitches then connects and shoots off the obsticle. B; doesnt move at all. no wires seem to be shorting out, i waterproofed it before was ever drove. im stumped and would like help on what i should do... please and thanks. also the stock moter seems a little less touchy and alot more speed. any good motor sizes i should switch to? thanks for the help |
02-26-2011, 02:49 PM | #2 | |
RCC Addict Join Date: May 2010 Location: Los Altos, California
02-26-2011, 03:31 PM | #3 |
so would the adjustment be in the back or will i have to get a servo strecher and sdjust through that?
02-26-2011, 03:34 PM | #4 | |
which radio do you have? if its the stock 27mhz, then i dont think there is a EPA. (EPA=end point adjustment) Oh but after reading it more carefully, i think it could just be a BEC issue or a faulty Servo. Can you do this again and see if the light on your receiver shuts off? if it does shut off, then your Servo is drawing too much amperage, so you will need a External BEC. | |
02-26-2011, 06:56 PM | #5 |
Is this a new rig, or bought used? What battery are you using? What do you mean by, "also the stock moter seems a little less touchy and alot more speed." Did you change the motor?? If so, what did you change it to???? |
02-26-2011, 07:10 PM | #6 |
Newbie Join Date: Feb 2009 Location: Indian Rocks
| I just went through the same problem .the ESC was bad.
02-26-2011, 07:15 PM | #7 |
its new, and the battery is a venom power, 4200MAH 7.2 volts NIMH. it just seems like there is now low power or a constant speed/rythm. should i just buy a better servo for the long run and a different radio? |
02-26-2011, 07:37 PM | #8 | |
id say get a new ESC and a external BEC! | |
