02-26-2011, 09:16 PM | #1 |
Quarry Creeper Join Date: Nov 2009 Location: East Greenville
| fried mamba micro pro
well i fried one of my mamba micro pros today, pluged in my battery it did its beeping thing and started smoking and when ever i plug a battery in the other esc that wasent smoking just blinks yellow so with this being said a, will cc cover fix this or will i have to shell out 60 to get it fixed b) is my other esc ok,why does it blink yellow, and c) where can i find another mamba micro pro cheap
02-27-2011, 01:17 AM | #2 | |
RCC Addict Join Date: May 2010 Location: Los Altos, California
As for your other ESC, you need to calibrate it or bind your RX to TX. to calibrate, hold your throttle, and turn on the switch, Green will flash. once it flashes red, go full reverse. then yellow, keep it in neutral, and itll do another like 10 beeps. after that it should be good to use | |
