02-26-2011, 09:17 PM | #1 |
Newbie Join Date: Jan 2011 Location: Columbus
| Rooster Crawler Help
I re programmed my esc today now when I get to something thats not flat like trying to climb fire place it just stops and a green light comes on. Whats causing this? Thanks
02-26-2011, 09:58 PM | #2 |
RCC Addict Join Date: Jan 2009 Location: Crawlifornia
I had this problem once with an XL5. Here is a test for you to try. Adjust your throttle trim to full forward. It will want to move forward or should with no throttle. If it does, go to this fireplace with it still adjusted forward and slowly pull the throttle. Let me know if that works. May sound stupid to you but sometimes the easiest things stump us. If it does work then ur throttle trim is set back to much. If it works, then adjust it back just enough that it does want to pull the truck forward on it's own and test reverse. Make sure both work and ur tits up. Then again I may be talkin out my ass, but free fix is better than callin it a dead esc. |
02-27-2011, 03:45 AM | #3 | |
(I'm assuming when you say "reprogram" you mean updating the ESC firmware?) | |
03-02-2011, 02:44 PM | #4 |
Rock Crawler Join Date: Jul 2006 Location: Hobbywing
| csuangka@teamnovak.com in case you haven't resolved this.
