02-27-2011, 06:58 PM | #1 |
Newbie Join Date: Nov 2009 Location: Mt. Sterling
| Shift servo?
I have a scx10 running a rc4wd xr4 radio and I am wanting to put a summit trans in it but I did not know if I would be able to run a shift servo off a three position switch w/o any epa/exp adjustments?
02-28-2011, 12:27 AM | #2 |
Probably not. You can get a servo stretcher though, it'll give you those adjustments without having to upgrade your radio.
02-28-2011, 06:49 AM | #3 |
You can probably do it, but it would take some futzing with the servo arm & linkage to get the correct throw without overloading either the trans or servo. A servo stretcher would likely be a better option. |
02-28-2011, 09:01 AM | #4 |
Newbie Join Date: Nov 2009 Location: somerville
You could use something like this, traxxas #4968x. I took all the other shift linkage off my summit trans and hooked this to the hole in the shifter rod. It's worked fine so far.
03-01-2011, 09:54 AM | #5 |
Quarry Creeper Join Date: Apr 2009 Location: Ottawa, ON, Canada
I've been using a servo saver on my Bruiser's shifter for 20 years, simple, cheap and effective.
03-01-2011, 07:12 PM | #6 |
Thanks for the replies, I am new to the hobby and don't know much yet.
