02-27-2011, 07:17 PM | #1 |
Newbie Join Date: Jan 2011 Location: union
| Honcho jumping and hessitating at take off......NEED HELP!!
I got a honcho and on a fully charged battery I can take off full throttle and the truck will hessitate and jump real bad. Used to I could go fast in reverse and then full forward throttle and pop the front end straight up. Not now, just hessitation and jumping. It does the same thing if I try to climb over a pillow in the floor. Another thing is when the front tires are in the least bit of a bind, the truck won't do anything (turn or go) until I pick the front off the ground a little, then the servo will turn right then left. Then the truck will go and turn again. Please HELP!!
02-27-2011, 11:04 PM | #2 |
Quarry Creeper Join Date: Jun 2010 Location: lexington nc
can u give a little bit more info as to what eletrionics r on it. sounds like u might have some probs with them espicialy if they are stock like the speed control. my ax10 did that i emailed axial an told them i was haveing a prob with myspeedo an they r sending me a replacment. the ae1 is just junk took my lrp ai outta my tc4 prob was gone.
02-27-2011, 11:21 PM | #3 |
Rock Crawler Join Date: Apr 2010 Location: Kelowna, B.C., Canada
Most likely you stock speed control's bec is not sufficient enough to power both your reciever and you servo. What is happening is like a brown out. A bec should solve your problem. I recommend a Castle Creations bec, they are only about 20-25 dollars and can be programmed for different voltages. If you program it at 6 volts you should get more torque with the stock servo. Hope this helps. |
02-28-2011, 06:54 AM | #4 | |
Did a CC BEC, no more issues. | |
