02-28-2011, 03:14 PM | #1 |
Pebble Pounder Join Date: Jun 2010 Location: Ontario,Canada
| Mamba Max Pro ESC
What do I need to set up a Mamba Max Pro in my Losi Comp Crawler? I just ordered one but the in field programming card doesnt look like it will set it up right with no reverse delay? Does anyone know for sure? Thanks for the help Last edited by Garry; 02-28-2011 at 04:22 PM. Reason: spelling mistake. |
02-28-2011, 03:19 PM | #2 |
Quarry Creeper Join Date: Dec 2010 Location: Princeton Mass
The cc program card should also work as a castle link. My mmp was set for forward only no reverse and I had to set it up via a laptop for both.
02-28-2011, 03:24 PM | #3 |
02-28-2011, 03:52 PM | #4 |
yes it will work with windows 7, both my computers are running windows 7 and have catle link on them
02-28-2011, 03:55 PM | #5 |
Mamba, with an A, not an O. You can program all you need with your radio. It's explained in the instructions. No Castle Link or Field Programmer needed. |
02-28-2011, 04:20 PM | #6 |
Thanks for all the help. It will be here in 2 weeks cant wait to run it.
02-28-2011, 04:27 PM | #7 |
02-28-2011, 04:29 PM | #8 |
Good to know I just picked up windows 7 to upgrade from vista and never thought about if would work or not.
03-01-2011, 08:20 PM | #9 |
Quarry Creeper Join Date: Jul 2009 Location: Long Island
I thought i read it doesnt work on a 64 bit vista or 7. Anyway i just got mine, its for my scx10 what should i program the mmp for? I know crawler reverse but what about all the other features like drag brake, do i leave it on smart sence? Ill be running a 13.5t brushless motor with 13mm rotor. |
03-02-2011, 12:22 AM | #10 |
Newbie Join Date: Feb 2011 Location: BC
just a heads up, watch out the firmware when u update it. if the latest beta version did not work well, just go back to early final version as they r "final" yeah, i did have some "turbo" boost when used beta. went back to early final all solved. lol yes, CC field card works well on any window |
03-02-2011, 10:08 AM | #11 | |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
03-03-2011, 04:21 AM | #12 |
What other settings would you guys use on an scx10? Any boost? Drag brake on to my liking or is the 213% setting the way to go? Lipo cut off good at 3.2?
03-03-2011, 04:29 PM | #13 |
RCC Addict Join Date: Mar 2008 Location: SSF
03-03-2011, 05:08 PM | #14 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
Question. You going to run a micro pro in a LCC. With what motor? I ask, because those worm gears are going to make it hot. 55t should be fine though, just dont think anything above that will be good. I could be wrong though. Got 2 in my XR with 35t's. Just thinking the worms will make it work harder.
