02-28-2011, 04:11 PM | #1 |
Quarry Creeper Join Date: Oct 2009 Location: Hudson
| 2 crawlers and 2 DX3E radios?
If I have two crawlers can I use a Spektrum DX3E radio for each of them and run them at the same time? So, crawler #1 will be ran using a DX3E and crawler #2 will be ran using another DX3E at the same time??? Thanks in advance. RIZ |
02-28-2011, 04:13 PM | #2 |
RCC Addict Join Date: Nov 2004 Location: union
yep it wont be any problem. |
02-28-2011, 04:15 PM | #3 |
Do I need to do anything special to make it work or just turn everything on and just start crawling? RIZ |
02-28-2011, 04:17 PM | #4 |
02-28-2011, 04:53 PM | #5 |
Thanks bro. So much easier than mixing and matching crystals. RIZ |
02-28-2011, 05:21 PM | #6 |
RCC Addict Join Date: Sep 2010 Location: Malta, NY
i just have a nother questionhow many of your vehicals can you use the dx3e. like if you have the right amount of rx's can i run all of my crawlers and my monter truck on the same radio?
02-28-2011, 05:25 PM | #7 |
The dx3e is only good for one receiver. However, you could pick up another compatible transmitter with a larger model memory and still use the same sr300 receivers that you already have.
02-28-2011, 05:39 PM | #8 |
You can use it for as many vehicles as you want. The downside to not having model memory if that you will have to reset your trims and end points every time you switch vehicles. If you dont mind doing that you can save yourself the cash and put it towards more vehicles.
