03-01-2011, 03:05 PM | #1 |
Pebble Pounder Join Date: Jan 2011 Location: london,England
| how do you bypass the internal bec on m2 dig
hi how do you bypass the internal bec on a m2 dig so that i can put a cc bec on.
03-01-2011, 03:16 PM | #2 |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
if you're going to run the BEC through the receiver, just remove the red wires from both esc connections.
03-01-2011, 03:17 PM | #3 |
Some searching will basically say, "Wire up the CC BEC, remove signal wire from servo connector & plug it (signal wire) into the RX. Plug the BEC into the servo plug (multiple ways to do this, some are solder in others use an adaptor). Enjoy the newfound power to the servo." You don't "bypass" the ESC internal by switching something off. |
