03-05-2011, 03:16 PM | #1 |
Newbie Join Date: Dec 2010 Location: oshkosh
| Help with battery packs
This has probly been mentioned on here, but can anyone tell me how to rearrange the cells in a battery pack? I have a 7 cell stick pack I want to make into a hump pack. My lhs wants $20 per battery to do this. Any help would be greatly appreciated. Thanks. |
03-05-2011, 04:56 PM | #2 |
Have you ever soldered batteries before? Have a GOOD gun or iron to solder with? Are your current packs soldered or welded? |
03-07-2011, 10:08 AM | #3 |
I think theyre welded. Ive tried to reattach battery tabs before but I couldn't get them to hold. I have a cheap walmart iron. Someone told me there would be wires soldered on the battery but there are l shaped tabs on the battery. I don't want to take them apart unless I'm sure I'll get them back together.
03-07-2011, 10:13 AM | #4 |
Quarry Creeper Join Date: Jun 2010 Location: lexington nc
post up a pic. i have done the same thing befor. its realy not that hard the first thing u do is make sure u have everything u need an then clean all spots to b soldered. i use a bit of sandpaper to roughen up the battery contacts to help with the solder joint. get some good solder i go to radio shack an buy the silver solderi think its called stay silv or something like that hope this helps
