03-05-2011, 04:51 PM | #1 |
Pebble Pounder Join Date: Dec 2010 Location: Veneta
| More FXR ESC Question
I just got a fxr esc. I took it to lhs and had them solder it together. While they were at it, I had them install cc bec. The removed red wire form esc plug. I just want to verify the esc went in the throtte port and the bec went in the bind port in SR300 reciever. Thanks in advance.
03-05-2011, 05:01 PM | #2 |
correct
03-05-2011, 05:02 PM | #3 |
Thank You!
03-05-2011, 05:06 PM | #4 |
Quarry Creeper Join Date: Jan 2010 Location: USA
Yes, that should do it.
03-05-2011, 05:12 PM | #5 |
Thanks!
03-05-2011, 06:44 PM | #6 |
I have some more questions. Will hotwire work if red esc wire is pulled because of bec? Does the power need to be on? How do you program without hotwire? Thanks.
03-05-2011, 07:20 PM | #7 |
No, I think it has to be plugged in to use the hotwire. Did they cut the wire or just unplug it from the connector? If they unplugged it then you can just plug it back in when you need it. You can program it with the LED's but if you have a hotwire I would use it because you get more options. |
03-05-2011, 07:34 PM | #8 |
03-05-2011, 07:57 PM | #9 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
if im not mistaken: you can still use the hotwire without the red wired in the plug just power up the FXR with whatever battery ypou are using.... should be golden... |
03-05-2011, 08:30 PM | #10 |
Thanks for the replys. I tried using hotwire, but it kept saying plug in esc to hotwire. I did figure out how to use the esc to program (lhs kept intructions). They just unpluged red wire. Would i plug redwire back in, then unplug bec while programmming? Thanks again.
03-05-2011, 10:27 PM | #11 |
RCC Addict Join Date: Mar 2008 Location: SSF
It does need the red wire to mount to the Hot-Wire for programming. It doesn't need it for LED programming. |
03-06-2011, 05:47 AM | #12 | |
