03-05-2011, 08:24 PM | #1 |
Rock Crawler Join Date: Nov 2010 Location: Denver
| FXR Hot Wire
Is it a good idea to get a FXR Hot Wire? What are some of the positive things I can do with this? Thanks |
03-05-2011, 09:20 PM | #2 |
I think that it is worth it, much quicker than watching lights flash. It gives you a few more options on some of the settings. It is really nice if you are running dual esc's because you can easily check them both out.
03-05-2011, 09:46 PM | #3 |
Quarry Creeper Join Date: Jun 2010 Location: NTXRCC
Also you can't change the throttle profile with out a hotwire on FXR. You can on the Pro, but you really need to be able to change the forward and reverse throttle profiles to get a crawler dialed in right imo.
03-05-2011, 10:43 PM | #4 | |
Can you please explain this "throttle profiles" to me? Thanks | |
03-06-2011, 05:36 AM | #5 | |
You can do a "linear" profile for fwd/rev, this means you move the throttle trigger a little, you get a little power to the motors. Basically the stock programming. You can also change it, like I did, where near "0" throttle, moving the throttle a bunch gives almost no power to the motors, then squeeze a bit more and the power level rises faster than throttle movement. This makes it a little easier to creep fwd/rev even while moving around the rocks and if my fniger twitches a bit, the rig won't jump on me. You can do seperate profiles for fwd & rev. I have a few profiles made & saved, I just plug my laptop in, pick a profile & load it. | |
03-07-2011, 12:18 AM | #6 |
Quarry Creeper Join Date: Aug 2009 Location: Golden, CRAWLERADO
itis worth it. you get more tuning options and can also update the software.
03-07-2011, 08:07 AM | #7 |
Thanks for the help folks, I will start looking around for one then. |
03-07-2011, 02:51 PM | #8 |
03-07-2011, 04:29 PM | #9 |
So, can I program more than one esc with the Hotwire? Or do I need a separate hotwire for each FXR esc I have?
03-07-2011, 05:52 PM | #10 | |
It is used for programming, save settings and then disconnect. It does NOT remain connected. | |
03-07-2011, 10:18 PM | #11 | |
Thanks for the help. | |
