03-05-2011, 08:36 PM | #1 |
Quarry Creeper Join Date: Sep 2010 Location: too close to LRC.... Jealous????
| nothing works right....
I must be doing something wrong at everything I do, electronics wise anyways....... First I just put a New 35t handwound in the Losi, and it hesitates right when I hit the throttle..... If I hold the throttle its fine but right when I let off and try to hit again its jumpy for a second and hesitates a little... the setup is: losi esc ccbec 35t brood handwound No caps, maybe this is what I need, if so tell me which ones and where to put them please..... second my lrp esc started smoking in my slasg so I put a new castle SV2 in and now first the wires blew off the motor, then the one of the bullet connecters started smoking and this motor is also real glitchy like its hesitating too until it gets going.....and it builds heat real quick, like 1-2mins in the wires, esc, and motor..... the only changes I made to this setup is changed the bullets from 4mm to 3.5 becuase its all I had setup Castle sv2 tekin 5.5 redline 3s Please help direct me in the right direction to get these problems fixed.....I am about to pull my hair out...... or quit all together.... LMAO |
03-05-2011, 09:47 PM | #2 |
Rock Crawler Join Date: Dec 2005 Location: West Omaha
Actually sounds like your geared too high in both cases. That will cause the problems except for the wires blowing off. Not sure about that one.
03-06-2011, 12:13 AM | #3 | |
now the slash is geared 16/86 which is pretty smallish for the setup..... I expect it to be warm but get that way near as fast as it does.... Like I just goosed around in my basement for a few minutes, no topspeed runs or even barely full throttle....... and its hott.... | |
03-06-2011, 08:19 AM | #4 |
03-06-2011, 08:29 AM | #5 |
Quarry Creeper Join Date: Feb 2010 Location: Knee deep in a creek with a fish on the line
I think you might be to big on the pinion. Must of the guys running the losi are running 13-14t on the pinion, and a smaller turn on the motor. You might want to look at Eeepee thread in the losi section , as he is one of the few who are running brushed motors with success in the losi.
03-06-2011, 08:45 AM | #6 | |
Run the stock pinion size at the very least. Secondly, you're gonna have to maintain that motor as best as you can if you want to get any amount of decent lifespan from it. And know when to say when with the throttle. | |
03-06-2011, 10:08 AM | #7 |
| yeah the stock pinion was a 20t, but wheelspeed sucks for this thing.....I had a 28t on the stock motor...and it was never glitchy like this, which makes me think I might need a cap or two..... I dunno
03-06-2011, 10:53 AM | #8 | |
Quarry Creeper Join Date: Dec 2008 Location: Australia
So the glitching is cogging because of the lack of a sensor in the SV2 and the blowing off of the bullet connectors probably comes from trying to draw a little bit to much current through those tiny 3.5mm connectors. With the 16/86 gearing it is geared to do 90 mph and for goofing around at low speed. You would probably want to be geared around 8/90 if you wanted to continue using the 5.5T motor with the SV2 or try using a 2S lipo. | |
03-06-2011, 07:54 PM | #9 | |
03-07-2011, 10:24 PM | #10 |
any more insight on any of these? I would really appreciate it
03-10-2011, 11:51 PM | #11 |
still unsure on the losi.... there is a pause when I hit full throttle and it cogs while in a bind...... and more on the slash, the esc gets real hot, real fast... It blows the soldered wires off the motor and it even overheated tonight and shut off.....and it also cogs real bad |
