Brushless motor recommendation After almost getting into Crawling one year ago I had to take a break but want to take it up again. I've started building my MOA again and now I'm thinking about boing with two Mamba Max Pros and at least 4S Lipo. But now I'm wondering which brushless motor I can use for this setup. Any recommendations? |
If you are set on brushless, I would recommend a set of 17.5 540 style motors. Tekin makes the smoothest ones I have crawled with so far, and they would be my recommendation for the XR10 with a 12 to 14t (stock) pinion. |
Thanks for the suggestions. I forgot to mention why I want to go brushless. I have some Worminator MOA axles lying around and want to give them a try. I will try the 17.5 Tekin motors. |
Re: Brushless motor recommendation I run mmp with tekin redline 13.5t and the 13mm high tourque rotor on 3s in my wraith and its a beast! I'm sitting at almost 12 lbs. |
