03-09-2011, 11:03 AM | #1 |
Quarry Creeper Join Date: Jan 2010 Location: UAE in the GCC
| Mamba Micro HELP
hey .... ive been running dual mamba micro pros since october in my xr-10 with HH 45T's and a CC BEC ..... red wires pulled out and the switches are soldered together in the board so here's my problem ... got me my vanquish cases and plates installed ..... spaced up the pinions ... and did my looooooong throttle tests while holding the rig up just to see if the motors and cases would heat up (just to check if the pinion spacing was too tight) ..... while doing this .... my front axle just kept on turning even after i let go of the throttle .... pulled the battery out to stop it ..... plugged it back in and i only have one esc arming and beeping ..... the front esc which kept throttling away wont engage .... it just keeps on blinking red ... ive tried removing the wire which goes to the rx and tried plugging it back in again (this usually works for all castle esc's) .... but it still doesnt want to engage ..... i need your help ..... anybody have issues like this before??? |
03-09-2011, 11:06 AM | #2 |
The neutral point for your front ESC is wrong. You need to adjust it on the radio a bit until the light on the ESC turns off. Sounds like you may have the throttle channel reversed too. You want green light with forward throttle and red light with reverse. |
03-09-2011, 11:21 AM | #3 | ||
i tried adjusting the neutral but its just not engaging .... it doesnt do that beep beep thing like the rear esc when i plug int the batteries | ||
03-09-2011, 11:26 AM | #4 |
Make sure it is plugged into the RX properly then. Fast red flashes indicate no radio signal. Other than that, try rolling back firmware and reinstalling. If that doesn't work you may have a bad one. |
03-09-2011, 11:27 AM | #5 |
when i unplug the rear esc from the rx .... the red light goes blink blink with the front esc ..... i plug in the rear back in the rx and it engages and does that beep beep thing ..... so i tried the same with the front esc ..... nothing .... red light just keeps on blinking ..... im thinking its not reading or receiving signal from the Rx? HELP please .... |
03-09-2011, 11:28 AM | #6 | |
yes its a fast red blinker .... i tried switching Rx's .... same thing ... i'll try to rollback the firmware .... question is i got this thing soldered up all together with the BEC running with the battery wires all soldered together .... do i have to unsloder them just so that i can use castle link? worst part is i removed the on/off switch .... the castle link doesnt recognize the devices cos they all power up simultaneously Last edited by strawb; 03-09-2011 at 11:36 AM. | |
03-09-2011, 11:37 AM | #7 |
I wanna be Dave Join Date: Oct 2006 Location: Milwaukie OR
Try re-calibrating. I had issues with the rear ESC not wanting to drag brake, and it was because the epa's were too high.
03-09-2011, 11:40 AM | #8 |
03-09-2011, 11:48 AM | #9 | |
Rock Crawler Join Date: Apr 2006 Location: Hartland, MI
03-09-2011, 12:00 PM | #10 |
im still trying to figure out how i can use castlelink without unsoldering them .....
03-09-2011, 12:08 PM | #11 |
03-09-2011, 12:13 PM | #12 |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
03-09-2011, 12:20 PM | #13 | |
| its not .... you can use castlelink even with all of them soldered together!!!! Quote:
i re-calibrated them at the same time ..... thanks for all the tips gentlemen .... mamba micros are alive and kicking! rolled back on the firmware and went back up again to V1.29 and everything is back to normal .... | |
03-09-2011, 12:27 PM | #14 |
03-09-2011, 12:49 PM | #15 |
Good deal,I'll have to try that some time,Didn't work for me when I did the first setup. |
