03-09-2011, 04:21 PM | #1 |
Quarry Creeper Join Date: Jan 2011 Location: 801
| ATTN: wantAsummit Mix Unit Users, LF Help
Okay before I go tinker again and attemt to fry some electronics, heres my crappy drawn under the influence mock up oh how I will do my setup and need someone to chime in and slap me or tell me its ok or what i need to change |
03-09-2011, 06:29 PM | #2 |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
i dotn have this product,b ut based on his page, you're correct, you want to remove the power wire from all connections except rear esc (probably does not matter which esc, the board just needs power), the bec, and the servo. the only power going to the RX is the BEC so for your side questions in the image, the top is YES, connect it that powers the WAS board.. the bottom is NO, only the BEC and SERVO should have red wires going to the RX. Last edited by T3rry; 03-09-2011 at 06:32 PM. |
03-09-2011, 06:37 PM | #3 |
Rock Crawler Join Date: Feb 2010 Location: Chapin, South Carolina
I honestly have no idea, PM the wantasummit person. |
03-09-2011, 06:41 PM | #4 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
| your post was very worth while and informative, we all appretiate it. to the OP, your drawing will work perfectly fine as is, using the one ESC to power the dig, and the BEC powering only the RX and servo. that is exactly how I used to wire mine. (also a cleaner version of your wiring setup if you wish) how I am currently wired is like the following picture, when I was wired like your drawing my one ESC that had the red wire still hooked up hit LVC very early. with my new setup it does not, (the only drawback is running 6v to the servo) (I am not using FXR's and it may just be cause of the very poor built in BEC of my sidewinder ESC) Last edited by fred0000; 03-09-2011 at 06:46 PM. |
03-09-2011, 07:09 PM | #5 |
@Fred, if I dont program the BEC to any certain voltage will it dtill work ok?
03-09-2011, 07:13 PM | #6 | |
you could also check the output of the BEC with a volt meter/multimeter. good luck | |
03-10-2011, 05:58 AM | #7 |
Rock Crawler Join Date: Feb 2008 Location: Nebraska
On my setup one of the ESCs has the red wire pulled. The other ESC is powering the mix controller and the receiver. My BEC is powering my steering servo directly. |
03-10-2011, 07:42 AM | #8 |
