03-10-2011, 09:02 AM | #1 |
Quarry Creeper Join Date: Nov 2009 Location: Tipp City
| unbalanced 2s lipo
I've got a 2s 5800mah lipo that is showing 1.18 volts on 1 cell and 5.33 volts on the other. Is there anything I can do to save it?
03-10-2011, 09:09 AM | #2 |
Try to balance it. Otherwise, forget it. If you know someone who is pretty familiar with lipo's, they might be able to bring the low cell back up.
03-10-2011, 09:16 AM | #3 |
Quarry Creeper Join Date: Jan 2011 Location: Lyons, MI
I dont know 1.1 volts... if you do try and balance it out do it outside away fom anything you dont want to burn down
03-10-2011, 09:20 AM | #4 |
I wanna be Dave Join Date: Oct 2006 Location: Centered
If your charger has a recovery mode, try that first. 1.18 is pretty damn low, you've lost 2/3 of the cells nominal voltage. Duuuuuuuude's right, if you don't have the facility to attempt a recovery find someone who does...perhaps your local shop, and let them try. Just curious, what brand Lipo is it? |
03-10-2011, 09:26 AM | #5 |
Quarry Creeper Join Date: Dec 2009 Location: jackson,tn
that just happened to me 2 days ago on a 2s, it was a blue lipo, cheap but i had it over a year, i just threw it away and ordered a few more of them, just a bigger mah rating.
03-10-2011, 11:06 AM | #6 |
[QUOTE Just curious, what brand Lipo is it?[/QUOTE] tURNIGY |
03-10-2011, 11:16 AM | #7 |
03-10-2011, 12:15 PM | #8 |
03-10-2011, 12:18 PM | #9 |
Are you certain that the shown voltage is correct and not an error on the part of the charger?
03-10-2011, 03:02 PM | #10 | ||
iMax B6 charger and does have a lipo recovery setting Thanks for all the help but looks like I'm out a battery Going to sit the grandson down tonight and explain the differences in the batteries. | ||
03-10-2011, 03:29 PM | #11 |
03-10-2011, 03:34 PM | #12 |
Quarry Creeper Join Date: Jul 2005 Location: pleasant ridge
You can charge only the low cell thru the tap on ni setting. Once its up on voltage balance charge it. Outside on concrete. Just in case.
03-10-2011, 03:35 PM | #13 |
03-10-2011, 03:42 PM | #14 |
03-10-2011, 05:14 PM | #15 | |
2-I don't have any grandkids (at least, not proven in a court of law.....), but I do have a teenage son (also on this forum). Be nice to your grandson, he can learn a lesson while NOT getting PO'd at you. Remember, it may be tough for some to replace a battery pack (times are tight, RC batteries tend to be near the bottom of the list of "essentials....") but an impression to a younger person tends to be LIFELONG!! Look at the bright side, at least he didn't CHARGE the LiPO at a NiMH setting and burn down your house! | |
03-11-2011, 06:43 AM | #16 | |
I had a nice talk with him last night and he now understands. He's 15 and was like what's the difference, he figured a battery was a battery. So he now is a smarter 15 (kinda like staying at a Holiday Inn Express) | |
03-11-2011, 10:36 AM | #17 |
Rock Stacker Join Date: Jan 2011 Location: hellinois
wierd im having a simalar problem,it just happens to be that i have a 3s hobby people 2200mah 20c 11.1v . just started here in the elec. section to do some searching and rite off i seen this post so here i am , my charger is a sigma II eq and reading thru it i founnd it come equipped with a balance setting so i set it up all outside to try will post more if it works. |
03-11-2011, 11:17 AM | #18 |
Pebble Pounder Join Date: Jan 2011 Location: Mtz
1.18 volts is low for sure, but what about the 5.33 volts on the other cell, I would be more worried about that. With the low cell u just have to get rid of it, but with overcharged cell, doesn't it have to possibility of it igniting? From what I understand, 4.2 volts per cell was max. If u have anyother way of checking the lipo cells(charger read out or multimeter), I would do that and make sure your volt meter that u are using now is correct. One other thing, how did your battery get charged up so high in the first place? After the battery was run, 5.33 Volts is still higher than my charger would ever take it. Good luck and let us know what u end up doing.
03-11-2011, 12:07 PM | #19 | |
Charge a battery enough times without balancing and it will go way out of whack. The weaker cell will discharge further when used, and not hold a charge as well when its juiced back up. | |
