03-11-2011, 11:34 AM | #1 |
Pebble Pounder Join Date: Dec 2010 Location: Veneta
| Castle Link & Bec Questions
I just got the castle link. I want to up voltage of bec to 6 volts. I am not sure how to do this. I also wanted to verify that brown wire was negative. Thanks.
03-11-2011, 11:56 AM | #2 |
1-You need the CClink software on a PC 2-Attach the USB cable to PC, then the adaptor/link to the USB cable 3-Need power to the BEC 4-Start the software, make sure you get 2 green boxes in lower left of CC software box. (if there is an issue, follow directions/recommendations in CClink software) 5-Go to settings, see current value (likely 5.1 volts), hit down arrow to right of box and select voltage you want. 6-Now, "update" the setting to BEC You should be done, disconnect everything and go play. BTW, I just did this to mine last night. |
03-11-2011, 11:58 AM | #3 |
Quarry Creeper Join Date: Sep 2010 Location: Central MN H-Town
No need to power the bec to update it, just plug in using the castle link.
03-11-2011, 12:05 PM | #4 |
I must be missing something. I dont see any theing that says setings. My icon says Castle Link Graph View. I open it and its a graph.
03-11-2011, 12:18 PM | #5 |
I figured it out. For some reason the screen from start menu shortcut was different from desktop icon. Thanks for the help.
03-11-2011, 12:18 PM | #6 |
you'll need to click on the blue castle link icon, find it in start menu
