03-13-2011, 01:43 PM | #1 |
| 4PKS Help
I'm over looking something here... I set up my stuff just like Harley's Video's. MENU: PROG MIX 1 FWD -100 BRAK -100 MST TH SLV TH MODE ACT (ON) = But some how switches itself back off? OFST 0 MXMD MIX TRIM OFF MENU: PROG MIX 2 FWD -100 BRAK -100 MST TH SLV CH3 MODE ACT (ON) = But some how switches itself back off? OFST 0 MXMD MIX TRIM OFF But I have a few Problems... The MODE ACT keeps changing to (OFF) when I go back and look. Also my main screen DISP is on C1 not C2 like in the Video. Not sure how to change that. If that matters... I press PS1 and it says it turns on the P-MIX1 on... I pull the throttle and the bar on that ch just barley moves and flickers away. When I Press PS1 again and it turns the MIX off. The Throttle on that ch is fine... I have yet to get both ch's for the ESC's to show throttle at the same time. The Steering is showing up just fine. This has got me stumped... |
03-13-2011, 02:30 PM | #2 |
I got the Disp to show C2 now... But my PROG MIX 1 and 2 still show MODE: ACT (OFF)... And the only way to get it back to on it to reset everything. I try to change it to on and all it does is change to INH (OFF)...
03-13-2011, 03:12 PM | #3 |
OK.. Some how again... Not sure what I did... I stepped away for Min... Plugged the BEC in the RX and the Battery in. Light on the RX came on Green... Oh well.... Still trying to get my ESC's tpo respond now. The Servo is working... |
03-14-2011, 10:45 AM | #4 |
Quarry Creeper Join Date: May 2007 Location: Temecula, CA
Good info, I have a 4pks new in a box that I haven't used. This will help me setting it up. |
03-14-2011, 01:30 PM | #5 |
Rock Stacker Join Date: Mar 2011 Location: WA
On my 4pks when you power it on everything is off so what I have had to do is just hit the button that you mapped ch3 to (pm1 is mapped to ps2) and your screen will tell you PMix is off or on. |
