DIY dig switch I just bought a 250v/5A switch to use on my berg as a dig switch... How reliable are these switches? Which wire do i cut to connect(red or black)? I will just make one cut and let the rear axle freewheel instead of locking it into drag brake...will it still work? The axles need a bit of a force to run them around when the esc is off so i thought this will work. |
its hard to say how reliable it will be without knowing what it actually is but 5A isnt much when i made a dig switch i used 20A switches |
I've seen a thread in here where someone used this 5a switches but forgot which one was. |
I used the same 5A switch for two years before switching to a two ESC setup. You would want to wire your dig switch like this for it to work properly: http://ncrccrawlers.com/gallery2/d/7023-1/OCMDig.jpg |
What if i don't use the black wire on the rear motor(i'll only use one switch for the rear only)? |
Someone who understands electronics better would have to answer that. I only know that two of my friends tried that and ended up burning 5 switches before wiring the switch according to the diagram. After that no issues. |
