Thread: ax-2 problems
Old 03-15-2011, 10:03 PM   #1
Default ax-2 problems
i have a scx-10 with the ax-2 and 2.4gh setup. had it a little while and now it will not run. when i hook the battery up and turn it on it keeps beeping as if the remote was off. steering works so it has a link but no throttle? any help would be nice.
nhtoyotawheeler is offline   Reply With Quote
Old 03-15-2011, 10:07 PM   #2
check your throttle adjustment on your transmitter. sometimes this happens..
CRAWLIN5150 is offline   Reply With Quote
Old 03-15-2011, 10:19 PM   #3
i will check it but i have no throttle at all. it acts like the remote is off and keeps beeping. but the remote is on and it will steer while beeping?
Old 03-15-2011, 10:20 PM   #4
yes i know this use to happen with mine when i had it. The throttle trim is what you need to look at. if its too high or low this may happen
Old 03-15-2011, 10:29 PM   #5
no just checked and tried adjusting it nothing. just beeps,and beeps,but will steer and lights work?
Old 03-17-2011, 08:39 PM   #6
I joined the Band!
Try Rebinding the Transmitter and make sure you have you stuff plugged in right into the receiver....
skullking is offline   Reply With Quote
Old 03-17-2011, 09:17 PM   #7
Have you tried putting juice right to the motor to see if the motor spins. My guess is that the motor has failed, That is what it sounds like to me.
TedBull is offline   Reply With Quote
