03-16-2011, 12:20 PM | #1 |
Rock Stacker Join Date: Dec 2010 Location: naperville
| Dual esc problem MMP's
Ok so i wired them up together to the same deans connector for the battery, I had one programmed and calibrated before I did this, then I proceeded to program and calibrate the second esc after they were all connected, everything went fine up until I went to run the rig, forward but no reverse. I figured the MMP's had reprogrammed themselves, so I hooked one up to the castle link sure enough it was on forward w/o reverse, hooked up the second MMP and this is where things got weird, as soon as I connected it castle software said all the settings were corrupt, I reset it back to factory then programmed it again, all went well. Now I'm trying to calibrate it to my 4pl and the weird thing is that it arms itself and see's neutral(solid yellow light) but won't calibrate, hooked it back up to castle link and checked, there's no calibration numbers stored their all 0's, disconnected the MMP from everything else just to make sure theres no cross talk and still nothing, it can be programmed but not calibrated, and arms itself but does nothing, any ideas/thoughts.
03-16-2011, 12:46 PM | #2 |
Talked with castle and they said that is very weird and they want it sent in immediately so we'll see what they say.
03-16-2011, 03:05 PM | #3 |
Quarry Creeper Join Date: Nov 2010 Location: Canada
You need to program and calibrate them individually before you wire them up to the same plug. Calibrate the front then the rear and then wire them together. Disconnect the BEC too just to make sure. If you had one programmed and then wired them together and then tried to program the 2nd one, it would change all the settings for the 1st one. |
03-16-2011, 03:12 PM | #4 |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
Yep,Thats the same problem I had. Need to be set up,castle link,individually, then you can calibrate them to the radio. I also did that one at a time with the throttle channel. Then removed the red wires and plugged everything in its place. |
03-16-2011, 03:20 PM | #5 | |
RCC Addict Join Date: Jun 2009 Location: California
to plug your front ESC into Channel 2... Program it, then unplug it. Plug your rear ESC into channel 3...Program it. Plug the front back in and you should be ready to go...I also found when removing the red wire for some reason that they would uncalibrated themselves for some reason...Cant explain that..But when they are all plugged in everything always works. | |
03-16-2011, 04:05 PM | #6 | |
03-16-2011, 07:02 PM | #7 |
Problem is that the one esc is stuck in armed neutral and won't calibrate now or do anything, it thinks it's calibrated already but it's not. Castle said that should never happen and want me to send it in.
