03-16-2011, 02:54 PM | #1 |
Rock Stacker Join Date: Mar 2011 Location: apple valley
| Hitec 7955 on night crawler stock receiver
Will the servo fry my receiver? I was told i could still run this servo on my stock night crawler. but im not getting any response from my receiver.
03-16-2011, 03:07 PM | #2 |
Pebble Pounder Join Date: Dec 2010 Location: Midwest City
You can run it on the stock RX. In fact, I'm running a 7955 on my LNC with the stock RX ...but I am using a CC BEC. Are you using an external BEC with it? If not, you won't get the full power @ 6V and you will be limited the voltage of the internal BEC on the stock ESC. |
03-16-2011, 03:19 PM | #3 |
Rock Stacker Join Date: Feb 2005 Location: Mansfield
You probably have it plugged in backwards.
03-16-2011, 03:20 PM | #4 |
i am not useing an external bec. i was told that getting this servo would be better than my stock one cuz i was haveing some issues with the stock one. i do know that getting an external bec would be the best for it. but atm i cant get it due to being a lil broke. but im not getting any response from my truck.
03-16-2011, 03:36 PM | #5 |
| X2...make sure the black wire is on the ---> right side of RX The stock servo was terrible and upgrading to the 7955 was a great choice. Right now you are only getting 250oz of torque @ 4.8V which is a big improvement over stock. Getting a BEC allows you to use it at 6V and get the full 333oz of torque, if you have the available power might as well use it |
03-16-2011, 03:49 PM | #6 |
Ok guys thanks. I thought that maybe putting in the new servo made something go bad. but its just the factory radio and receiver again. This is the 2nd time in a week that they have went bad. You can hear surging power in the radio. once i bind it and take out the plug and pwr down the truck. and turn it back on there is no signal.
03-16-2011, 04:29 PM | #7 |
Rock Crawler Join Date: Apr 2006 Location: Thorp WA, more sheep than men...
w/out the bec the servo can overload the internal bec in the ESC killing the receiver... Plumb in a CC-BEC and set it for 6.0ish and go! |
