03-17-2011, 05:36 PM | #1 |
Quarry Creeper Join Date: Dec 2010 Location: vegas
| Mounting esc/rec./other things....
to Delrin skid plate? How do you guys do it? I have tried double sided tape/superglue/H.S. velcro. To no avale. I am running outcry D.M. esc, Novalink 2s lipo cutoff, and theres the rec, switch, bec. switch and bec are ok. Just not sure what to do here. Any pics of what you guys use will be great! And yes I tried the search button but no go there. Thnx in adavance guys/gals. Sabo |
03-17-2011, 06:18 PM | #2 |
I usually use either velcro or servo tape.
03-17-2011, 06:19 PM | #3 |
Goop/shoegoo, it sticks to EVERYTHING!! |
03-17-2011, 08:37 PM | #4 |
Hmmm... well as I said I tried velcro. Doesnt work for me. Servo tape, not sure what that is really but will look into it. Never thought of goop. Do you roughen up the surface or anything? Thnx for info.
03-17-2011, 08:46 PM | #5 |
Rock Crawler Join Date: Aug 2006 Location: Pinedale, WY
I use electrical tape to hold my elecs down about a dozen wraps on each
03-17-2011, 11:15 PM | #6 |
RCC Addict Join Date: Nov 2005 Location: Saving for Nationals!!
Try cleaning the surface with alcohol or windex before sticking the velcro, it's probably just dirty, I have never had an issue with it before.
03-17-2011, 11:18 PM | #7 |
Yeah I did that several times. I will try to sand the surface a lil bit then try it?? What you think?
03-17-2011, 11:36 PM | #8 |
| tape type adhesives usually prefer a nice smooth surface, I wonder if there is a protective plastic film on the delrin?? I have done that before and wondered why it didn't stick...
03-18-2011, 02:55 PM | #9 |
Quarry Creeper Join Date: May 2009 Location: Under Communist Occupation
E-6000
03-19-2011, 06:27 AM | #10 | |
It is thin enough that the servo won't really move, but thick enough to kill some vibration as well as shear off about the same time you would break the servo. Almost anywhere that handles RC stuff has/can get servo tape. | |
03-19-2011, 12:33 PM | #11 |
RCC Addict Join Date: Aug 2007 Location: Seattle
Double sided tape is a shit ton cheaper at auto parts stores then hobby shops. 3m makes the stuff that Lund uses to hold their junk to 1:1 trucks.
03-19-2011, 01:32 PM | #12 |
Ok here is a update...... I sanded down the surface to get the shiny/slick side smooth. I then remounted everything with double sided tape (3M) but I also used super glue on the bottom of the tape and skid plate. Seemed to work really really well so far. Will keep you guys aprised if anytrhing changes. Thnx for the advise/info. |
