03-19-2011, 01:07 PM | #1 |
Pebble Pounder Join Date: Mar 2011 Location: SW Iowa
| Mamba Max Pro - Help
Picked up a used mamba max along with a 5700k motor. Ditched the motor, and just putting the esc on a stock brushed ax10 with an nimh battery. Didn't get the castle link, so I'm just swinging the setup. Plugged it all in, and the esc is super glitchy. Running the throttle either direction makes it sputter. Just for fun, hooked the 5700 motor up and it seemed to work. I checked out the manual and tried to set it up manually. There are 3 leds, I never have seen the yellow one come on. When I plugged the 5700 motor in it set off the tones, the brushed motor never does make a tone. Without the castle link I can't tell what the settings are. I'm only assuming they are still set for brushless and possibly lipo. Any help? (Sorry, it was a Mamba Max, not the Pro) Last edited by dogsofwar; 03-19-2011 at 01:36 PM. Reason: mistaken esc |
03-19-2011, 01:22 PM | #2 |
RCC Addict Join Date: Mar 2008 Location: SSF
By default the ESC is set up for brushless. You can change it with your Tx and the directions. |
03-19-2011, 05:57 PM | #3 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
Yup its still in brushless mode. As Jeepindoug said you can change it using you Tx & the destructions in the booklet. |
09-24-2011, 02:47 PM | #4 |
Rock Crawler Join Date: Jan 2006 Location: woodpile aka HELL
im having the same issue, but the opposit. ive been trying to figure this thing out all morning, downloaded castlelink and for some reason it wont connect to my laptop, but ill try to connect my holmes bl to the mamba, makes the tones, tried to program it over the controller and it wont do a full roatation. so im assuming is stuck in brush mode, but how do you change it over to brushless?
09-24-2011, 02:58 PM | #5 | |
RCC Addict Join Date: Mar 2011 Location: Way out there!
09-24-2011, 03:02 PM | #6 |
still no luck, maybe ill try a different usb cable.
09-24-2011, 03:04 PM | #7 |
Did you read the instructions??..... http://www.castlecreations.com/suppo...s_ed_guide.pdf |
09-24-2011, 03:30 PM | #8 |
Rock Crawler Join Date: Aug 2011 Location: tri cities
Get the field link card and do it off that. I have a field link card for mine and it made it handy its a lot easier then having to deal with the computer
09-24-2011, 03:44 PM | #9 |
yeah for some reason i cant open the instructions, keeps freezing my computer.
09-24-2011, 03:51 PM | #10 |
09-24-2011, 03:53 PM | #11 |
ill turn the truck on, plug in the usb, no luck their. ill turn the esc off and the orange light stays on. works great with a brush motor. but i would like to try the brushless. ill delete the program an try to reinstall it
09-24-2011, 04:04 PM | #12 |
dang, yea litterally a brand new dell laptop lol about a week old.
09-24-2011, 04:21 PM | #13 |
Rock Crawler Join Date: Mar 2008 Location: 920 Valley of the Fox
09-24-2011, 05:00 PM | #14 |
ill take a look. it doesnt take a special usb cord dose it? im using a usb cord like what you would use for a blackberry or playstation controller. tried dowloading netFramework 3.5 and yeah. still not working
09-24-2011, 05:02 PM | #15 |
09-24-2011, 05:18 PM | #16 |
ill post a screan shot, it wont find the drivers for the mamba
09-24-2011, 05:27 PM | #17 |
09-24-2011, 06:07 PM | #18 |
Is that WIndows 7?? Is there a compatability mode to run the CC software as Windows XP??
09-25-2011, 12:59 PM | #19 |
yeah it windows 7. well if its not compatable then i hope thats the issue. i have a vista laptop i can try it on. ill give it a shot later on
09-25-2011, 01:24 PM | #20 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
On the CC website there are special instructions for installing the software under windows 7. http://www.castlecreations.com/suppo...ml#castlelink4
