03-20-2011, 06:14 AM | #1 |
Newbie Join Date: Jul 2009 Location: bogan australia
| Xbox power supply into 240-12.
So I got a few xbox 360 power supply cables laying around here and just glanced at them before I was going to chuck them. Reading the back caught my eye. 240 in and 12 out. At 12 volt there's 2 different amp outputs. One style has a 14.6amp output and another has 16amp output. What you need to do if your to do this is you cut the plug at the xbox end and strip all wires from the insulation. You will be left with 3 black. 3 yellow a red and a blue. Join the yellows together. That's positive. Join blacks together. They're earth. And join the red and the blue together. When this is done it triggers it to put 12 volt out instead of just 5 volt. Now plug it in. Maybe put a fuse in the 12v side and start charging. |
03-20-2011, 06:52 AM | #2 |
Rock Crawler Join Date: Aug 2006 Location: Pinedale, WY
nice I have a old xbox 360 that doesn't work anymore maybe i can put it to use |
