03-21-2011, 12:48 PM | #1 |
Newbie Join Date: Jan 2011 Location: Southern Indiana
| 7.4 Lipo in a 7.2 crawler?
Buddy of mine put a 7.4 5000 lipo in his MaxStone 8 this weekend vs. the 7.2 stock battery. Runs stronger and almost 4 times as long as the stock battery. Is this safe to do? The extra run time and power has me wanting to go the same route, but not if its not safe. If it is safe, would an even larger lipo be safe? Say a 7000 or higher? Thanks, |
03-21-2011, 12:52 PM | #2 |
Rock Crawler Join Date: Mar 2008 Location: 920 Valley of the Fox
You need a LVC for lipo (low voltage cutoff) or you will damage or possible explode your lipo! You can get a ESC with the LVC built-in or a external LVC. also 5000 & 7000 is maH = run time, more Mah more run time.
03-21-2011, 01:00 PM | #3 |
Whoa!! Thanks for the heads up! I will let him know asap. Looks like a new battery and LVC for me Thanks for the help |
03-21-2011, 06:57 PM | #4 |
Quarry Creeper Join Date: Apr 2010 Location: Hells Hole
Easy way to remember it is the volts are your horsepower and the mah is your gas tank. also remeber more mah equals more weight same with your cells.
03-22-2011, 08:22 AM | #5 |
Newbie Join Date: Mar 2011 Location: San Diego
Ok so with that said. I am looking at running dual lipos in my SCX10. I was wanting to run dual 2s lipos. Do i run them in tandem and will that make me a 4s? if it will work then will i need a ESC that handles 4s lipos?
03-22-2011, 08:32 AM | #6 | |
Any problems with a 11.1v volt 5250 lipo in my rig? http://www.maxamps.com/products.php?cat=59 | |
03-22-2011, 10:25 AM | #7 |
You need to check to see what the max voltage is on the ESC. If it is rated for 8.4V only, then 11.1V might let some majic smoke out.
03-22-2011, 10:31 AM | #8 |
03-25-2011, 10:57 PM | #9 |
Rock Crawler Join Date: Jan 2011 Location: bridgeport
If its the stock ESC that the maxstone came with,dont do it!...invest in a ESC that can handle 11.1v,it will be one of your best investements...how's the maxstone looking now a days?
03-29-2011, 01:35 PM | #10 | |
To run series, (batt A pos to ESC+, batt A neg to batt B pos, batt B neg to ESC-) you'd then be at 4S, not adding together the mAh. Lots of voltage, good ground speed, so-so runtimes. Better make absolutely certain the ESC you're going to use is rated for 4S, or your shake-n-bake will turn into sizzle-n-smoke in a hurry. In parallel, both batteries need to be identical in every rating. In series, you can mix voltages, but everthing else must match exactly. (mAh, C rating) And it would be very wise to make sure if you're mixing batteries, they come from the same mfr, so the ratings are tested the same and should be a known match. This is one area where mix-n-match makes for very bad karma. | |
03-29-2011, 02:36 PM | #11 |
never did it with lipo, but with nicd and nimh you could mix 2 packs with different voltages since all you are doing is using wires to connect some of the cells instead of battery bars. so with lipo i dont see why you couldnt do a 2s and a 3s together since its wire beween 2 cells instead of being soldered directly together
