03-23-2011, 12:26 PM | #1 |
Pebble Pounder Join Date: Jan 2011 Location: london,England
| Savox sc 1258 Tg
Hi I have this servo and would like to know what volt it is set at, because i would like to get the full 20kg but to get would I have to turn my bec to 6.0v to make it 20kg or is it set already set at this . Thanks for any help guys Last edited by vegas1973; 03-23-2011 at 01:12 PM. |
03-23-2011, 01:51 PM | #2 |
if you have a cc bec and havent changed it from the factory setting of 5.1-5.2v, then it will need turned up to 6v with a castle link
03-23-2011, 03:00 PM | #3 |
RCC Addict Join Date: Apr 2008 Location: Sacramento
The servo is not set at a voltage it is designed to run on a certain voltage, usually some where between 4.8-7.4 volts, running the servo at its max voltage will give you the best performance. So like stated above if you are running a Castle BEC then setting it to 6 volts will give your the best performance, if you don't have a Castle BEC I highly recommend getting one and a Castle link to program it if you do not have one.
