03-24-2011, 01:44 AM | #1 |
RCC Addict Join Date: Jun 2008 Location: In the woods
| problems
a week or so ago I had my motor smoke in my scale truck.it still runs,but now I cant ease into the throttle and get it to work.only works at full throttle.do I need to just replace it?and it wants to glitch now also. thanks. |
03-24-2011, 03:38 AM | #2 |
RCC Addict Join Date: Mar 2010 Location: Alburtis
Try rebuilding it first. That is if its a rebuildable type. cut the comm, replace the brushes and oil the bearings. Wes |
03-24-2011, 06:30 PM | #3 |
ok thanks.it is an axial 27T and i have a cpl 55 turns laying around i thought about using anyway to slow it down some.running hpi gear reduction and killer tranny case behind it.
03-24-2011, 07:00 PM | #4 | |
Rock Crawler Join Date: Oct 2009 Location: Michigan
If its a Axial can motor chances are there is nothing you can do with it, other than pitch it in the trash. If you like the speed just replace it with a Traxxas 12t can motor, they are cheap and gave an inturnal fan and probably about the same-ish speed. These motors are pretty tough too. An exturnal BEC may help with the glitching also, if you are not already running one. | |
03-24-2011, 08:08 PM | #5 | |
