03-25-2011, 05:52 AM | #1 |
Rock Crawler Join Date: Feb 2010 Location: Chapin, South Carolina
| Sidewinder V2 Help
I've got my sidewinder installed but I'm not sure how to reset it. I can steer but not go forward or backwards.. I'm planning on re-setting it so I can do the option again. I do not have a castle link.
03-25-2011, 06:06 AM | #2 |
RCC Addict Join Date: Sep 2007 Location: Hallsville, Tx
Make sure you have it set to brushed or brushless, depending on what kind of motor you have,
03-25-2011, 09:58 AM | #3 | |
Rock Crawler Join Date: Jul 2009 Location: greeley
Use your transmitter to reprogram it. If you no longer have the programing sheet go to the Castle website to see what the "beeps" mean. As far as I know there is no "reset". | |
03-25-2011, 10:05 AM | #4 |
When you are not touching the throttle, does the controller show any lights?
03-25-2011, 03:49 PM | #5 |
03-25-2011, 04:42 PM | #6 |
Quarry Creeper Join Date: May 2010 Location: Plumas county
The motor wires will just determine your motor rotation..... If you turn it on while having the controller at full throttle (holding) it'll boot up and give off some beeps with a green light, once it shows the red light flashing (after a series of beeps) full reverse. Then a few more ring and yellow light flashing. Let off. Wait for it to cycle it's rings again and after a few seconds when you think it's done it'll do it again arming the esc. Just ignore me. Go to the website and follow the manual. |
03-25-2011, 05:41 PM | #7 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
With the SV2 Red is Pos & white is Neg. Not the usual red & black. This might be you prob. |
