03-25-2011, 05:02 PM | #1 |
Rock Crawler Join Date: Feb 2010 Location: Sturgis
| Puller motor cutting out
I just installed a 454 puller on my mrc and it rolled for a couple feet then I stopped to turn around and it wouldnt move. I reprogramed everything changed battery finally I set it on the table hit the throttle again an it worked. So after a bit of messing around I can get it to run , but when I let off the throttle it stops and all I have to do is tap on the case with something. I can even get it to fire tapping with my finger but the end of my allen drver works better. Dosent matter where I tap , but seems to work better towards the rearof the can. Any body have an idea whats going on ?
03-25-2011, 05:06 PM | #2 |
What ESC and battery? Sounds like there may be a brush hanging on there. Be sure the brush wires are free and not smooshed up against the brush hood. Try pushing on a brush and see if it comes to life.
03-25-2011, 05:11 PM | #3 |
LNC esc 2s 2800mah 25-35c battery . The copper wires are smushed against the can , is that bad ? I have to go to work in a sec I will take pics tonight. whats the hood ? And could you maybe insert a pic of how it should look and I will try that out.
03-25-2011, 05:16 PM | #4 |
And should they spark when they are running. Not a huge spark , but I bet it would start some gas on fire kinda spark.
03-25-2011, 06:31 PM | #5 |
Minor acring (the spark) is normal for a brushed motor as the brushes "jump" on the comm. "Smooshed" against the can is could be a problem. i would pop the brush springs off and make sure the brush slides in the hood nice a nd free. |
03-26-2011, 12:07 AM | #6 |
took the whole thing apart only to find a spring wasnt seated in the groove to push the brush against the com. Well it was a good learning experience. Im off to bed now .
03-26-2011, 12:08 AM | #7 |
P.s. Thanks guys.
