Thread: Servo Issues.
Old 03-31-2011, 11:24 AM   #1
Default Servo Issues.
I recently bought a used XR10 with 5955 servo on it. I bought a new dsx3e radio and am using the reciever that came with it. It started turning all the way left and locking up when you first start it up. you can plug and unplug it a few times and it will finally work right. The servo was a little beat up so I went ahead and bought a new one hoping that was the problem but it still does it. I run a BEC set a 6 volts. any suggestions?
muddigger123 is offline   Reply With Quote
Old 04-01-2011, 08:36 AM   #2
Nobody???
Old 04-01-2011, 08:52 AM   #3
Take the servo horn off, turn the truck on and let the servo center and turn your steering trim to zero. Then straighten your wheels, put the horn back on and set your EPAs...
JeremyH is offline   Reply With Quote
Old 04-01-2011, 01:38 PM   #4
+1.
Then come back and say, either:
-It now works
-It's still doing the same thing.
Charlie-III is offline   Reply With Quote
Old 04-01-2011, 08:29 PM   #5
still doing same thing. I had already tried that but thanks for suggestion.
